<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Accelerometer]]></title><description><![CDATA[<p dir="auto">Hi All,</p>
<p dir="auto">I was wonder if the digital inputs of the Monarco will work with this accelerometer. The outputs from it are only 0-3.3V. I'm fairly sure it's ok, just checking!</p>
<p dir="auto"><a href="https://www.adafruit.com/product/163">https://www.adafruit.com/product/163</a></p>
]]></description><link>https://forum.rexygen.com/topic/12/accelerometer</link><generator>RSS for Node</generator><lastBuildDate>Sat, 18 Apr 2026 16:03:23 GMT</lastBuildDate><atom:link href="https://forum.rexygen.com/topic/12.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 19 Mar 2019 18:52:43 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Accelerometer on Wed, 20 Mar 2019 07:15:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/11">@mikeyh</a> Did you mean analog inputs? The accelerometer outputs range from 0 to 3.3V... In general, it will work. Note that you'll not fully use the resolution of the A/D converter on the Monarco HAT and you'll be limited to 2 axes as the Monarco HAT has 2 analog inputs.</p>
<p dir="auto">If you meant digital inputs indeed, then it won't work. Logic high voltage of the DIs on the Monarco HAT is 3.5 V to 30 V.</p>
<p dir="auto">Hope this helps, let me know.</p>
]]></description><link>https://forum.rexygen.com/post/13</link><guid isPermaLink="true">https://forum.rexygen.com/post/13</guid><dc:creator><![CDATA[jaroslav_sobota]]></dc:creator><pubDate>Wed, 20 Mar 2019 07:15:10 GMT</pubDate></item></channel></rss>
