<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Installation of REXYGEN 2.50.10-testing]]></title><description><![CDATA[<p dir="auto">Hello, there is REXYGEN pre-release version 2.50.10-r5 available for testing. For upgrading REXYGEN on your Raspberry Pi please follow the instructions:</p>
<li>change the source for the APT packaging system:</li>
<pre><code>sudo nano /etc/apt/sources.list.d/rexcontrols.list
<p dir="auto">replace the contents with:</p>
<pre><code>deb http://download.rexcontrols.cz/repositories/debian-rex-2.50-testing/ buster non-free
<p dir="auto">Save and exit.</p>
<li>Update packages cache:</li>
<pre><code>sudo apt update
<li>Uninstall REXYGEN runtime modules:</li>
<pre><code>sudo apt purge rexygen-runtime
sudo apt autoremove
<li>Install the newest REXYGEN runtime modules:</li>
<pre><code>sudo apt install rexygen-runtime
<li>As for the newest development tools for your PC, please download the installer from <a href="http://download.rexcontrols.com/rex/2.50-testing/windows/">http://download.rexcontrols.com/rex/2.50-testing/windows/</a></li>
<p dir="auto"><strong>Note: the instructions assume that you are using Raspbian Buster or newest Raspberry OS. If not, please upgrade your system.</strong></p>
]]></description><link>https://forum.rexygen.com/topic/120/installation-of-rexygen-2-50-10-testing</link><generator>RSS for Node</generator><lastBuildDate>Mon, 07 Sep 2026 06:45:16 GMT</lastBuildDate><atom:link href="https://forum.rexygen.com/topic/120.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 26 Jun 2020 13:48:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Installation of REXYGEN 2.50.10-testing on Mon, 17 Aug 2020 13:29:38 GMT]]></title><description><![CDATA[<p dir="auto">Hi Guenther,</p>
<p dir="auto">the official release version is still 2.50.9 for now. However we are not far from public release of 2.50.10 and the pre-release version is available in above mentioned post.</p>
<p dir="auto">Kind regards<br />
]]></description><link>https://forum.rexygen.com/post/480</link><guid isPermaLink="true">https://forum.rexygen.com/post/480</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Mon, 17 Aug 2020 13:29:38 GMT</pubDate></item><item><title><![CDATA[Reply to Installation of REXYGEN 2.50.10-testing on Sat, 15 Aug 2020 09:18:20 GMT]]></title><description><![CDATA[<p dir="auto">Hi, How to install the official version. Made a fresh buster installation and followed the standard procedure of the REXYGEN getting started description. But the install was 2.50.9. Or is there still only the testing version released?</p>
]]></description><link>https://forum.rexygen.com/post/475</link><guid isPermaLink="true">https://forum.rexygen.com/post/475</guid><dc:creator><![CDATA[gninaus]]></dc:creator><pubDate>Sat, 15 Aug 2020 09:18:20 GMT</pubDate></item><item><title><![CDATA[Reply to Installation of REXYGEN 2.50.10-testing on Mon, 27 Jul 2020 11:15:17 GMT]]></title><description><![CDATA[<p dir="auto">Hi Peter,</p>
<p dir="auto">sorry for difficulties once again. The situation is changing quickly before the actual release. Please, use following link to download the development tools:</p>
<p dir="auto"><a href="http://download.rexcontrols.com/rex/2.50-testing/windows/">http://download.rexcontrols.com/rex/2.50-testing/windows/</a></p>
<p dir="auto">Thanks for understanding.</p>
]]></description><link>https://forum.rexygen.com/post/455</link><guid isPermaLink="true">https://forum.rexygen.com/post/455</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Mon, 27 Jul 2020 11:15:17 GMT</pubDate></item><item><title><![CDATA[Reply to Installation of REXYGEN 2.50.10-testing on Fri, 24 Jul 2020 06:14:10 GMT]]></title><description><![CDATA[<p dir="auto">&lt;snip&gt;</p>
<li>As for the newest development tools for your PC, please download the installer from <a href="http://download.rexcontrols.com/rex/2.50.10-r5/windows/REXYGEN-2.50.10.12237-x64.exe">http://download.rexcontrols.com/rex/2.50.10-r5/windows/REXYGEN-2.50.10.12237-x64.exe</a></li>
<p dir="auto">It appears that also this link is no longer there and need to be updated as well.</p>
]]></description><link>https://forum.rexygen.com/post/453</link><guid isPermaLink="true">https://forum.rexygen.com/post/453</guid><dc:creator><![CDATA[RexPeter]]></dc:creator><pubDate>Fri, 24 Jul 2020 06:14:10 GMT</pubDate></item><item><title><![CDATA[Reply to Installation of REXYGEN 2.50.10-testing on Mon, 20 Jul 2020 18:56:04 GMT]]></title><description><![CDATA[<p dir="auto">Hi Peter,</p>
<p dir="auto">sorry for difficulties with REXYGEN upgrade. The address of repositories is:</p>
<p dir="auto">Let me know if it worked for you.</p>
]]></description><link>https://forum.rexygen.com/post/451</link><guid isPermaLink="true">https://forum.rexygen.com/post/451</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Mon, 20 Jul 2020 18:56:04 GMT</pubDate></item><item><title><![CDATA[Reply to Installation of REXYGEN 2.50.10-testing on Mon, 20 Jul 2020 17:17:47 GMT]]></title><description><![CDATA[<p dir="auto">Hi Jiri,</p>
<p dir="auto">Just change the url as below:<br />
<img src="/assets/uploads/files/1595265291562-92ab5e75-bce8-40fb-b405-d1fd0c42cff6-image.png" alt="92ab5e75-bce8-40fb-b405-d1fd0c42cff6-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Saved the file and tried it again.</p>
<p dir="auto"><img src="/assets/uploads/files/1595265444105-460d13c4-9448-49da-9e46-cab89bbe0bc8-image.png" alt="460d13c4-9448-49da-9e46-cab89bbe0bc8-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">So this still does not work....</p>
]]></description><link>https://forum.rexygen.com/post/450</link><guid isPermaLink="true">https://forum.rexygen.com/post/450</guid><dc:creator><![CDATA[RexPeter]]></dc:creator><pubDate>Mon, 20 Jul 2020 17:17:47 GMT</pubDate></item><item><title><![CDATA[Reply to Installation of REXYGEN 2.50.10-testing on Mon, 20 Jul 2020 15:08:45 GMT]]></title><description><![CDATA[<p dir="auto">Thanks a lot Jiri!<br />
I will give it a trial.</p>
Peter</p>
]]></description><link>https://forum.rexygen.com/post/449</link><guid isPermaLink="true">https://forum.rexygen.com/post/449</guid><dc:creator><![CDATA[RexPeter]]></dc:creator><pubDate>Mon, 20 Jul 2020 15:08:45 GMT</pubDate></item><item><title><![CDATA[Reply to Installation of REXYGEN 2.50.10-testing on Mon, 20 Jul 2020 12:19:38 GMT]]></title><description><![CDATA[<p dir="auto">Hi, Peter.<br />
The repository for the release candidate has been replaced with a testing repository.<br />
Please change the <code>-r5</code> section of the URL address to <code>-testing</code>.</p>
<p dir="auto">Best Regards,<br />
Jiri</p>
]]></description><link>https://forum.rexygen.com/post/448</link><guid isPermaLink="true">https://forum.rexygen.com/post/448</guid><dc:creator><![CDATA[admin]]></dc:creator><pubDate>Mon, 20 Jul 2020 12:19:38 GMT</pubDate></item><item><title><![CDATA[Reply to Installation of REXYGEN 2.50.10-testing on Sat, 18 Jul 2020 19:57:10 GMT]]></title><description><![CDATA[<p dir="auto">Hi Tomas,</p>
<p dir="auto">I just tried to update a Raspberry to the r5 release, but get this problem:<br />
<img src="/assets/uploads/files/1595102139745-45be13ea-65ac-4af1-a2b2-40f6474eca02-image.png" alt="45be13ea-65ac-4af1-a2b2-40f6474eca02-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">So I cannot get to the newest release right now. I did updated a few others without problems some time back.</p>
<p dir="auto">I will try another time again, maybe problem with server now?</p>
Peter</p>
]]></description><link>https://forum.rexygen.com/post/447</link><guid isPermaLink="true">https://forum.rexygen.com/post/447</guid><dc:creator><![CDATA[RexPeter]]></dc:creator><pubDate>Sat, 18 Jul 2020 19:57:10 GMT</pubDate></item></channel></rss>
