<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Deleting Archive from Target]]></title><description><![CDATA[<p dir="auto">Hi All,</p>
<p dir="auto">Sorry if this has been asked before, I have searched and didn't find anything.</p>
<p dir="auto">How do you delete archived (from TRND) data from the target device? Can it be deleted when you load a new configuration?</p>
]]></description><link>https://forum.rexygen.com/topic/154/deleting-archive-from-target</link><generator>RSS for Node</generator><lastBuildDate>Mon, 09 Nov 2026 17:38:38 GMT</lastBuildDate><atom:link href="https://forum.rexygen.com/topic/154.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 21 Oct 2020 01:00:59 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Deleting Archive from Target on Wed, 04 Nov 2020 08:50:30 GMT]]></title><description><![CDATA[<p dir="auto">Hi Tomas,</p>
<p dir="auto">Thank you for the reply</p>
<p dir="auto">Rebooting, swapping executive and AFLUSH work fine, new data being written to the disk in time period does not work though.</p>
]]></description><link>https://forum.rexygen.com/post/591</link><guid isPermaLink="true">https://forum.rexygen.com/post/591</guid><dc:creator><![CDATA[MikeyH]]></dc:creator><pubDate>Wed, 04 Nov 2020 08:50:30 GMT</pubDate></item><item><title><![CDATA[Reply to Deleting Archive from Target on Wed, 04 Nov 2020 08:30:29 GMT]]></title><description><![CDATA[<p dir="auto">Hi Mike,</p>
<p dir="auto">thanks for update on this. The reboot isn't necessary. The file should be created also when:</p>
<li>new write of archived items is performed to the disk with specified period</li>
<li>swapping executives</li>
<li><strong>when AFLUSH is triggered - see: <a href="https://www.rexygen.com/doc/ENGLISH/MANUALS/BRef/AFLUSH.html">https://www.rexygen.com/doc/ENGLISH/MANUALS/BRef/AFLUSH.html</a></strong></li>
<p dir="auto">Let me know if it work for you.</p>
]]></description><link>https://forum.rexygen.com/post/590</link><guid isPermaLink="true">https://forum.rexygen.com/post/590</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Wed, 04 Nov 2020 08:30:29 GMT</pubDate></item><item><title><![CDATA[Reply to Deleting Archive from Target on Tue, 03 Nov 2020 22:37:49 GMT]]></title><description><![CDATA[<p dir="auto">Update! I have tried this and it seems you can run the command while the execution is running. But for a new archive file to be created you need to reboot.</p>
]]></description><link>https://forum.rexygen.com/post/588</link><guid isPermaLink="true">https://forum.rexygen.com/post/588</guid><dc:creator><![CDATA[MikeyH]]></dc:creator><pubDate>Tue, 03 Nov 2020 22:37:49 GMT</pubDate></item><item><title><![CDATA[Reply to Deleting Archive from Target on Tue, 03 Nov 2020 21:22:38 GMT]]></title><description><![CDATA[<p dir="auto">Thank you Tomas,</p>
<p dir="auto">If I use the block to run the command to delete the archive. Can this be done while the process is running, will REX create a new file straight away? Or should I reboot once the file is deleted?</p>
]]></description><link>https://forum.rexygen.com/post/587</link><guid isPermaLink="true">https://forum.rexygen.com/post/587</guid><dc:creator><![CDATA[MikeyH]]></dc:creator><pubDate>Tue, 03 Nov 2020 21:22:38 GMT</pubDate></item><item><title><![CDATA[Reply to Deleting Archive from Target on Mon, 26 Oct 2020 19:43:13 GMT]]></title><description><![CDATA[<p dir="auto">Sure <img src="https://forum.rexygen.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=6d51e091ff9" class="not-responsive emoji emoji-android emoji--wink" style="height:23px;width:auto;vertical-align:middle" title=";)" alt="😉" /> Have a look at function block called EPC - <a href="https://www.rexygen.com/doc/ENGLISH/MANUALS/BRef/EPC.html#x265-26400015">https://www.rexygen.com/doc/ENGLISH/MANUALS/BRef/EPC.html#x265-26400015</a></p>
<p dir="auto">For details on how to use the EPC function block, head to example on MP3 Playback: <a href="https://www.rexygen.com/example-projects/0304_External_Programs/0304-02_MP3_Playback/0304-02_MP3_Playback.html">https://www.rexygen.com/example-projects/0304_External_Programs/0304-02_MP3_Playback/0304-02_MP3_Playback.html</a></p>
]]></description><link>https://forum.rexygen.com/post/575</link><guid isPermaLink="true">https://forum.rexygen.com/post/575</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Mon, 26 Oct 2020 19:43:13 GMT</pubDate></item><item><title><![CDATA[Reply to Deleting Archive from Target on Thu, 22 Oct 2020 20:01:43 GMT]]></title><description><![CDATA[<p dir="auto">Perfect, thank you Tomas. Can the command be run via a block?</p>
]]></description><link>https://forum.rexygen.com/post/573</link><guid isPermaLink="true">https://forum.rexygen.com/post/573</guid><dc:creator><![CDATA[MikeyH]]></dc:creator><pubDate>Thu, 22 Oct 2020 20:01:43 GMT</pubDate></item><item><title><![CDATA[Reply to Deleting Archive from Target on Thu, 22 Oct 2020 14:40:35 GMT]]></title><description><![CDATA[<p dir="auto">Hi Mike,</p>
<p dir="auto">thanks for your question.<br />
There is only one way how to delete the archived data - just delete the files/folders on the target device.<br />
Following line will delete all the archived data:</p>
<pre><code>sudo rm -rf /rex/arc/
]]></description><link>https://forum.rexygen.com/post/572</link><guid isPermaLink="true">https://forum.rexygen.com/post/572</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Thu, 22 Oct 2020 14:40:35 GMT</pubDate></item></channel></rss>
