<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Logging a String]]></title><description><![CDATA[<p dir="auto">Hi All,</p>
<p dir="auto">I'd like to log observation notes (text) written in a HMI text box. Can you log such an event to a TRND block so you can compare it to other events (temperatures etc) in your TRND or Archive?</p>
]]></description><link>https://forum.rexygen.com/topic/155/logging-a-string</link><generator>RSS for Node</generator><lastBuildDate>Thu, 10 Sep 2026 10:33:40 GMT</lastBuildDate><atom:link href="https://forum.rexygen.com/topic/155.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 22 Oct 2020 03:28:50 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Logging a String on Tue, 10 Nov 2020 07:52:08 GMT]]></title><description><![CDATA[<p dir="auto">Oh I see, that’s an easy fix.</p>
<p dir="auto">Thanks Jan</p>
]]></description><link>https://forum.rexygen.com/post/612</link><guid isPermaLink="true">https://forum.rexygen.com/post/612</guid><dc:creator><![CDATA[MikeyH]]></dc:creator><pubDate>Tue, 10 Nov 2020 07:52:08 GMT</pubDate></item><item><title><![CDATA[Reply to Logging a String on Tue, 10 Nov 2020 07:39:11 GMT]]></title><description><![CDATA[<p dir="auto">You're welcome, Mike.<br />
The Python block must be checked when installing Rexygen Studio (it is not part of the default installation).<br />
<img src="/assets/uploads/files/1604993631440-python_install.png" alt="Python_install.PNG" class=" img-fluid img-markdown" /></p>
<p dir="auto">Cheers<br />
]]></description><link>https://forum.rexygen.com/post/610</link><guid isPermaLink="true">https://forum.rexygen.com/post/610</guid><dc:creator><![CDATA[reitinge]]></dc:creator><pubDate>Tue, 10 Nov 2020 07:39:11 GMT</pubDate></item><item><title><![CDATA[Reply to Logging a String on Tue, 10 Nov 2020 00:00:23 GMT]]></title><description><![CDATA[<p dir="auto">Thank you Jan,</p>
<p dir="auto">How do I gain access to the Python block? I have the latest version of REXYGEN but it does not show in my library.</p>
<p dir="auto"><img src="/assets/uploads/files/1604966363260-27436544-c172-4a2d-a2a3-ea8817169204-image.png" alt="27436544-c172-4a2d-a2a3-ea8817169204-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.rexygen.com/post/609</link><guid isPermaLink="true">https://forum.rexygen.com/post/609</guid><dc:creator><![CDATA[MikeyH]]></dc:creator><pubDate>Tue, 10 Nov 2020 00:00:23 GMT</pubDate></item><item><title><![CDATA[Reply to Logging a String on Mon, 09 Nov 2020 11:35:37 GMT]]></title><description><![CDATA[<p dir="auto">Hi Mike,<br />
string change checking can be easily done in a Python block:<br />
<a href="https://www.rexygen.com/doc/ENGLISH/MANUALS/BRef/PYTHON.html">https://www.rexygen.com/doc/ENGLISH/MANUALS/BRef/PYTHON.html</a><br />
You can compare the previous value of a string input with the current one, and if the values ​​differ, you can set the logical output to true and connect that output to the ARS:run input.</p>
<p dir="auto">There is probably other solution with the String blocks:<br />
<a href="https://www.rexygen.com/doc/ENGLISH/MANUALS/BRef/BRef_ENGch11.html">https://www.rexygen.com/doc/ENGLISH/MANUALS/BRef/BRef_ENGch11.html</a><br />
and Logic control blocks:<br />
<a href="https://www.rexygen.com/doc/ENGLISH/MANUALS/BRef/BRef_ENGch8.html">https://www.rexygen.com/doc/ENGLISH/MANUALS/BRef/BRef_ENGch8.html</a><br />
but the solution using a Python block is easier for me personally.</p>
]]></description><link>https://forum.rexygen.com/post/605</link><guid isPermaLink="true">https://forum.rexygen.com/post/605</guid><dc:creator><![CDATA[reitinge]]></dc:creator><pubDate>Mon, 09 Nov 2020 11:35:37 GMT</pubDate></item><item><title><![CDATA[Reply to Logging a String on Sun, 08 Nov 2020 23:14:56 GMT]]></title><description><![CDATA[<p dir="auto">Update,</p>
<p dir="auto">This seems of fixed itself! I have no issue using the ARS block or input.svg box now.</p>
<p dir="auto">I know the ARS block only logs when "run" is set to on. How can I have the ARS block only log the input value of the input.svg once each time the input is changed. Currently once I enter a value it continuously logs it, I only want the value to appear in log/archive once at from time I entered it. Then log the next input once and so on.</p>
<p dir="auto">Deleting the text from the HMI input.svg works but I wondered if there is a better way.</p>
]]></description><link>https://forum.rexygen.com/post/602</link><guid isPermaLink="true">https://forum.rexygen.com/post/602</guid><dc:creator><![CDATA[MikeyH]]></dc:creator><pubDate>Sun, 08 Nov 2020 23:14:56 GMT</pubDate></item><item><title><![CDATA[Reply to Logging a String on Fri, 06 Nov 2020 02:17:58 GMT]]></title><description><![CDATA[<p dir="auto">Hi Jan,</p>
<p dir="auto">When trying to use the ARS block and/or the MHI Input.svg I get the attached error. <a href="/assets/uploads/files/1604629075038-download-error.csv">Download error.csv</a></p>
]]></description><link>https://forum.rexygen.com/post/599</link><guid isPermaLink="true">https://forum.rexygen.com/post/599</guid><dc:creator><![CDATA[MikeyH]]></dc:creator><pubDate>Fri, 06 Nov 2020 02:17:58 GMT</pubDate></item><item><title><![CDATA[Reply to Logging a String on Wed, 04 Nov 2020 08:53:44 GMT]]></title><description><![CDATA[<p dir="auto">Thank you Jan</p>
]]></description><link>https://forum.rexygen.com/post/592</link><guid isPermaLink="true">https://forum.rexygen.com/post/592</guid><dc:creator><![CDATA[MikeyH]]></dc:creator><pubDate>Wed, 04 Nov 2020 08:53:44 GMT</pubDate></item><item><title><![CDATA[Reply to Logging a String on Wed, 04 Nov 2020 08:20:03 GMT]]></title><description><![CDATA[<p dir="auto">Hi Mike,<br />
you are right, the HMI Input component can be used for text after changing <strong>format</strong> to <em>text</em> in the component <strong>Options</strong>.</p>
<p dir="auto">Documentation for Rexygen HMI can be found here:<br />
<a href="https://www.rexygen.com/doc/ENGLISH/MANUALS/RexHMI/RexHMI_ENG.html">https://www.rexygen.com/doc/ENGLISH/MANUALS/RexHMI/RexHMI_ENG.html</a></p>
]]></description><link>https://forum.rexygen.com/post/589</link><guid isPermaLink="true">https://forum.rexygen.com/post/589</guid><dc:creator><![CDATA[reitinge]]></dc:creator><pubDate>Wed, 04 Nov 2020 08:20:03 GMT</pubDate></item><item><title><![CDATA[Reply to Logging a String on Tue, 03 Nov 2020 20:04:23 GMT]]></title><description><![CDATA[<p dir="auto">Thank you Tomas,</p>
<p dir="auto">I will try that. I do not need to read the string back to the HMI. Just have it available in the archive CSV. The purpose is to put an observational comment against an event, parameter change etc. That way when looking at the archive data I can see a logged comment as to why and when I changed the parameter.</p>
<p dir="auto">I assume the HMI Input.svg is ok to use for text?</p>
]]></description><link>https://forum.rexygen.com/post/585</link><guid isPermaLink="true">https://forum.rexygen.com/post/585</guid><dc:creator><![CDATA[MikeyH]]></dc:creator><pubDate>Tue, 03 Nov 2020 20:04:23 GMT</pubDate></item><item><title><![CDATA[Reply to Logging a String on Tue, 03 Nov 2020 13:16:11 GMT]]></title><description><![CDATA[<p dir="auto">Hi Mike,</p>
<p dir="auto">thank you for your question. It is possible to write string to Archives using function bloc called ARS - <a href="https://www.rexygen.com/doc/ENGLISH/MANUALS/BRef/ARS.html">https://www.rexygen.com/doc/ENGLISH/MANUALS/BRef/ARS.html</a></p>
<p dir="auto">However it is quite challenging to read out the strings back from Archive to the running algorithm. I would suggest to write simple cyclic string buffer in REXLANG just for your purpose. Therefore you can easily compare the strings within running algorithm using String library function blocks (or equal functions embedded in REXLANG).</p>
<p dir="auto">Kind regards<br />
]]></description><link>https://forum.rexygen.com/post/583</link><guid isPermaLink="true">https://forum.rexygen.com/post/583</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Tue, 03 Nov 2020 13:16:11 GMT</pubDate></item></channel></rss>
