<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Output to Analoge output]]></title><description><![CDATA[<p dir="auto">what is wrong here it is a normal CNR block with the value 1680 I place it outside the subsystem block directly on the output Extentons__xS51_1_AO1 I measure 4.2 volts I place the CNR block in the subsystem block it gives no output to the output Extentons__xS51_1_AO1</p>
<p dir="auto"><img src="/assets/uploads/files/1603747630869-scan.png" alt="scan.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.rexygen.com/topic/156/output-to-analoge-output</link><generator>RSS for Node</generator><lastBuildDate>Mon, 16 Mar 2026 06:42:04 GMT</lastBuildDate><atom:link href="https://forum.rexygen.com/topic/156.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 26 Oct 2020 21:27:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Output to Analoge output on Tue, 27 Oct 2020 09:14:58 GMT]]></title><description><![CDATA[<p dir="auto">Hi Martijn,</p>
<p dir="auto">please, check the TagVisibility parameter of Goto flag - if it is set to "local" it is not visible to the MB driver. Also check the output of REXYGEN Compiler which will tell you details about wrong setup of flags.</p>
]]></description><link>https://forum.rexygen.com/post/577</link><guid isPermaLink="true">https://forum.rexygen.com/post/577</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Tue, 27 Oct 2020 09:14:58 GMT</pubDate></item></channel></rss>
