<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Database Write]]></title><description><![CDATA[<p dir="auto">is there a limit to the number of lines you can add to the ODBC database driver ?.</p>
<p dir="auto">if I add another line, he gives a fault with everything I remove that line again, it is fine again</p>
<p dir="auto">see here under my mysql_ioconfig.rio</p>
<p dir="auto">ODBC {<br />
Connection              "DRIVER=MySQL;SERVER=<em><strong><strong><strong>;PORT=</strong></strong></strong></em>;DATABAS"<br />
"E=<em><strong><strong><strong>;UID=</strong></strong></strong></em>;PWD=*******;;"<br />
#Comment1               "Archive modes: 0=disable, 1=alarm(columns Time,Alar"<br />
#"mID,Code,Level,Value), 2=group(columns Time,GroupID,Value1,Value2,...), 3=gro"<br />
#"up(SQL with ? in order Time, ID, value1,...)"<br />
#Comment2               "Group modes: 0=disable, 1=read (last ID is accepted"<br />
#"), 2=read(last Time before now is accepted), 3=read(SQL first line is accepte"<br />
#"d), 129=write, 130=write with Time, 131=write SQL (with ?, Time is ?T)"<br />
#GUID                   *******<br />
Group {<br />
Name                    "Read"<br />
Mode                    3<br />
SQL                     "SELECT Schakelaar1Uit, Schakelaar1Aan, Schakelaar"<br />
"2Uit, Schakelaar2Aan, Schakelaar3Uit, Schakelaar3Aan, Schakelaar4Uit, Schakela"<br />
"ar4Aan, Schakelaar5Uit, Schakelaar5Aan FROM Schakelaars WHERE ID=1"<br />
Period                  2<br />
Items                   "Schakelaar1Uit,Schakelaar1Aan,Schakelaar2Uit,Scha"<br />
"kelaar2Aan,Schakelaar3Uit,Schakelaar3Aan,Schakelaar4Uit,Schakelaar4Aan,Schakel"<br />
"aar5Uit,Schakelaar5Aan"<br />
Type                    "ssssssssss"<br />
}<br />
Group {<br />
Name                    "Read2"<br />
Mode                    3<br />
SQL                     "SELECT Schakelaar6Uit, Schakelaar6Aan, Schakelaar"<br />
"7Uit, Schakelaar7Aan, Schakelaar8Uit, Schakelaar8Aan, Schakelaar9Uit, Schakela"<br />
"ar9Aan, Schakelaar10Uit, Schakelaar10Aan FROM Schakelaars WHERE ID=1"<br />
Period                  2<br />
Items                   "Schakelaar6Uit,Schakelaar6Aan,Schakelaar7Uit,Scha"<br />
"kelaar7Aan,Schakelaar8Uit,Schakelaar8Aan,Schakelaar9Uit,Schakelaar9Aan,Schakel"<br />
"aar10Uit,Schakelaar10Aan"<br />
}<br />
Group {<br />
Name                    "Read3"<br />
Mode                    3<br />
SQL                     "SELECT Schakelaar11Uit, Schakelaar11Aan, Schakela"<br />
"ar12Uit, Schakelaar12Aan, Schakelaar13Uit, Schakelaar13Aan, Schakelaar14Uit, S"<br />
"chakelaar14Aan, Schakelaar15Uit, Schakelaar15Aan FROM Schakelaars WHERE ID=1"<br />
Period                  2<br />
Items                   "Schakelaar11Uit,Schakelaar11Aan,Schakelaar12Uit,S"<br />
"chakelaar12Aan,Schakelaar13Uit,Schakelaar13Aan,Schakelaar14Uit,Schakelaar14Aan"<br />
",Schakelaar15Uit,Schakelaar15Aan"<br />
}<br />
Group {<br />
Name                    "Read4"<br />
Mode                    3<br />
SQL                     "SELECT Schakelaar16Uit, Schakelaar16Aan, Schakela"<br />
"ar17Uit, Schakelaar17Aan, Schakelaar18Uit, Schakelaar18Aan, Schakelaar19Uit, S"<br />
"chakelaar19Aan, Schakelaar20Uit, Schakelaar20Aan FROM Schakelaars WHERE ID=1"<br />
Period                  2<br />
Items                   "Schakelaar16Uit,Schakelaar16Aan,Schakelaar17Uit,S"<br />
"chakelaar17Aan,Schakelaar18Uit,Schakelaar18Aan,Schakelaar19Uit,Schakelaar19Aan"<br />
",Schakelaar20Uit,Schakelaar20Aan"<br />
}<br />
Group {<br />
Name                    "Read5"<br />
Mode                    3<br />
SQL                     "SELECT Schakelaar21Uit, Schakelaar21Aan, Schakela"<br />
"ar22Uit, Schakelaar22Aan, Schakelaar23Uit, Schakelaar23Aan FROM Schakelaars WH"<br />
"ERE ID=1"<br />
Period                  2<br />
Items                   "Schakelaar21Uit,Schakelaar21Aan,Schakelaar22Uit,S"<br />
"chakelaar22Aan,Schakelaar23Uit,Schakelaar23Aan"<br />
Type                    "ssssss"<br />
}<br />
Group {<br />
Name                    "Read6"<br />
Mode                    3<br />
SQL                     "SELECT SDimmer1Aan, SDimmer1Uit, SDimmer2Aan, SDi"<br />
"mmer2Uit, SDimmer3Aan, SDimmer3Uit, SDimmer4Aan, SDimmer4Uit, SDimmer5Aan, SDi"<br />
"mmer5Uit FROM Schakelaars WHERE ID=1"<br />
Period                  2<br />
Items                   "SDimmer1Aan,SDimmer1Uit,SDimmer2Aan,SDimmer2Uit,S"<br />
"Dimmer3Aan,SDimmer3Uit,SDimmer4Aan,SDimmer4Uit,SDimmer5Aan,SDimmer5Uit"<br />
}<br />
Group {<br />
Name                    "Read7"<br />
Mode                    3<br />
SQL                     "SELECT SDimmer6Aan, SDimmer6Uit, SDimmer7Aan, SDi"<br />
"mmer7Uit, SDimmer8Aan, SDimmer8Uit FROM Schakelaars WHERE ID=1"<br />
Period                  2<br />
Items                   "SDimmer6Aan,SDimmer6Uit,SDimmer7Aan,SDimmer7Uit,S"<br />
"Dimmer8Aan,SDimmer8Uit"<br />
Type                    "ssssss"<br />
}<br />
Group {<br />
Name                    "Read8"<br />
Mode                    3<br />
SQL                     "SELECT Dimmer1, Dimmer2, Dimmer3, Dimmer4, Dimmer"<br />
"5, Dimmer6, Dimmer7, Dimmer8, Dimmer9 FROM EntertainmentKnop WHERE Id=?10"<br />
Period                  2<br />
Items                   "Dimmer1,Dimmer2,Dimmer3,Dimmer4,Dimmer5,Dimmer6,D"<br />
"immer7,Dimmer8,Dimmer9,ID"<br />
Type                    "sssssssssi"<br />
}<br />
Group {<br />
Name                    "Read9"<br />
Mode                    3<br />
SQL                     "SELECT Dimmer10 FROM EntertainmentKnop WHERE Id=?"<br />
"2"<br />
Period                  2<br />
Items                   "Dimmer10,ID"<br />
Type                    "si"<br />
}<br />
Group {<br />
Name                    "Read10"<br />
Mode                    3<br />
SQL                     "SELECT SDimmer9Aan, SDimmer9Uit, SDimmer10Aan, SD"<br />
"immer10Uit, SDimmer11Aan, SDimmer11Uit, SDimmer12Aan, SDimmer12Uit, SDimmer13A"<br />
"an, SDimmer13Uit FROM Schakelaars WHERE ID=1"<br />
Period                  2<br />
Items                   "SDimmer9Aan,SDimmer9Uit,SDimmer10Aan,SDimmer10Uit"<br />
",SDimmer11Aan,SDimmer11Uit,SDimmer12Aan,SDimmer12Uit,SDimmer13Aan,SDimmer13Uit"<br />
}<br />
Group {<br />
Name                    "Read11"<br />
Mode                    3<br />
SQL                     "SELECT SDimmer14Aan, SDimmer14Uit, SDimmer15Aan, "<br />
"SDimmer15Uit, SDimmer16Aan, SDimmer16Uit, SDimmer17Aan, SDimmer17Uit, SDimmer1"<br />
"8Aan, SDimmer18Uit FROM Schakelaars WHERE ID=1"<br />
Period                  2<br />
Items                   "SDimmer14Aan,SDimmer14Uit,SDimmer15Aan,SDimmer15U"<br />
"it,SDimmer16Aan,SDimmer16Uit,SDimmer17Aan,SDimmer17Uit,SDimmer18Aan,SDimmer18U"<br />
"it"<br />
}<br />
Group {<br />
Name                    "Read12"<br />
Mode                    3<br />
SQL                     "SELECT SDimmer19Aan, SDimmer19Uit, SDimmer20Aan, "<br />
"SDimmer20Uit, SDimmer21Aan, SDimmer21Uit, SDimmer22Aan, SDimmer22Uit, SDimmer2"<br />
"3Aan, SDimmer23Uit FROM Schakelaars WHERE ID=1"<br />
Period                  2<br />
Items                   "SDimmer19Aan,SDimmer19Uit,SDimmer20Aan,SDimmer20U"<br />
"it,SDimmer21Aan,SDimmer21Uit,SDimmer22Aan,SDimmer22Uit,SDimmer23Aan,SDimmer23U"<br />
"it"<br />
}<br />
Group {<br />
Name                    "Read13"<br />
Mode                    3<br />
SQL                     "SELECT ?2 FROM Schakelaars WHERE ID=1"<br />
Period                  2<br />
Items                   "SchakelaarAanString,SchakelaarAan"<br />
Type                    "ss"<br />
}<br />
Group {<br />
Name                    "Write1"<br />
Mode                    131<br />
SQL                     "UPDATE SchakelaarStatusNaam SET Status=?1 WHERE I"<br />
"d=1"<br />
Period                  2<br />
Items                   "Schakelaar1Satus"<br />
Type                    "s"<br />
}<br />
Group {<br />
Name                    "Write2"<br />
Mode                    131<br />
"d=2"<br />
Period                  2<br />
Items                   "Schakelaar2Satus"<br />
Type                    "s"<br />
}<br />
Group {<br />
Name                    "Write3"<br />
Mode                    131<br />
"d=3"<br />
Period                  2<br />
Items                   "Schakelaar3Satus"<br />
Type                    "s"<br />
}<br />
Group {<br />
Name                    "Write4"<br />
Mode                    131<br />
"d=4"<br />
Period                  2<br />
Items                   "Schakelaar4Satus"<br />
Type                    "s"<br />
}<br />
Group {<br />
Name                    "Write5"<br />
Mode                    131<br />
"d=5"<br />
Period                  2<br />
Items                   "Schakelaar5Satus"<br />
Type                    "s"<br />
}<br />
Group {<br />
Name                    "Write6"<br />
Mode                    131<br />
"d=6"<br />
Period                  2<br />
Items                   "Schakelaar6Satus"<br />
Type                    "s"<br />
}<br />
Group {<br />
Name                    "Write7"<br />
Mode                    131<br />
"d=7"<br />
Period                  2<br />
Items                   "Schakelaar7Satus"<br />
Type                    "s"<br />
}<br />
Group {<br />
Name                    "Write8"<br />
Mode                    131<br />
"d=8"<br />
Period                  2<br />
Items                   "Schakelaar8Satus"<br />
Type                    "s"<br />
}<br />
Group {<br />
Name                    "Write9"<br />
Mode                    131<br />
"d=9"<br />
Period                  2<br />
Items                   "Schakelaar9Satus"<br />
Type                    "s"<br />
}<br />
Group {<br />
Name                    "Write10"<br />
Mode                    131<br />
"d=10"<br />
Period                  2<br />
Items                   "Schakelaar10Satus"<br />
Type                    "s"<br />
}<br />
Group {<br />
Name                    "Write11"<br />
Mode                    131<br />
"d=11"<br />
Period                  2<br />
Items                   "Schakelaar11Satus"<br />
Type                    "s"<br />
}<br />
Group {<br />
Name                    "Write12"<br />
Mode                    131<br />
"d=12"<br />
Period                  2<br />
Items                   "Schakelaar12Satus"<br />
Type                    "s"<br />
}<br />
Group {<br />
Name                    "Write13"<br />
Mode                    131<br />
"d=13"<br />
Period                  2<br />
Items                   "Schakelaar13Satus"<br />
Type                    "s"<br />
}<br />
Group {<br />
Name                    "Write14"<br />
Mode                    131<br />
"d=14"<br />
Period                  2<br />
Items                   "Schakelaar14Satus"<br />
Type                    "s"<br />
}<br />
Group {<br />
Name                    "Write15"<br />
Mode                    131<br />
"d=15"<br />
Period                  2<br />
Items                   "Schakelaar15Satus"<br />
Type                    "s"<br />
}<br />
Group {<br />
Name                    "Write16"<br />
Mode                    131<br />
"d=16"<br />
Period                  2<br />
Items                   "Schakelaar16Satus"<br />
Type                    "s"<br />
}<br />
Group {<br />
Name                    "Write17"<br />
Mode                    131<br />
"d=17"<br />
Period                  2<br />
Items                   "Schakelaar17Satus"<br />
Type                    "s"<br />
}<br />
Group {<br />
Name                    "Write18"<br />
Mode                    131<br />
"d=18"<br />
Period                  2<br />
Items                   "Schakelaar18Satus"<br />
Type                    "s"<br />
}<br />
Group {<br />
Name                    "Write19"<br />
Mode                    131<br />
"d=19"<br />
Period                  2<br />
Items                   "Schakelaar19Satus"<br />
Type                    "s"<br />
}<br />
}</p>
]]></description><link>https://forum.rexygen.com/topic/159/database-write</link><generator>RSS for Node</generator><lastBuildDate>Sun, 18 Oct 2026 03:03:36 GMT</lastBuildDate><atom:link href="https://forum.rexygen.com/topic/159.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 03 Nov 2020 15:52:09 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Database Write on Mon, 09 Nov 2020 21:23:58 GMT]]></title><description><![CDATA[<p dir="auto">Hi Martijn,</p>
<p dir="auto">in current REXYGEN version the total number of Groups in DB driver is limited to 32. It is a bug and it is fixed now. The fix will be present in next release version.</p>
<p dir="auto">Thank you for your report.</p>
]]></description><link>https://forum.rexygen.com/post/607</link><guid isPermaLink="true">https://forum.rexygen.com/post/607</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Mon, 09 Nov 2020 21:23:58 GMT</pubDate></item></channel></rss>
