<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Port configuration for REXYGEN Studio]]></title><description><![CDATA[<p dir="auto">Do I need to open more than only port 43981 in our firewall before I can download something to the PC with REXcore on it?</p>
<p dir="auto">I'm asking this because with only port 43981 it is not working and I get following message :</p>
<pre><code>Connecting to rex://admin@10.16.15.10:43981/  ...  FAILEDError: Timeout (code -102)
]]></description><link>https://forum.rexygen.com/topic/180/port-configuration-for-rexygen-studio</link><generator>RSS for Node</generator><lastBuildDate>Sun, 18 Oct 2026 03:10:56 GMT</lastBuildDate><atom:link href="https://forum.rexygen.com/topic/180.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 07 Jan 2021 15:24:35 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Port configuration for REXYGEN Studio on Fri, 08 Jan 2021 09:59:54 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for your reply, in the mean while it is working fine. Our IT-department made a small mistake in configuring the ports.</p>
]]></description><link>https://forum.rexygen.com/post/685</link><guid isPermaLink="true">https://forum.rexygen.com/post/685</guid><dc:creator><![CDATA[Apollo]]></dc:creator><pubDate>Fri, 08 Jan 2021 09:59:54 GMT</pubDate></item><item><title><![CDATA[Reply to Port configuration for REXYGEN Studio on Thu, 07 Jan 2021 20:59:15 GMT]]></title><description><![CDATA[<p dir="auto">Hi Kris,</p>
<p dir="auto">port 43981 in enough for diagnostics (REXYGEN Studio + REXYGEN Diagnostics).<br />
Other ports 8008 (http HMI) and/or 8009 (https HMI).</p>
<p dir="auto">Answer is no, 43981 should be enough. Are you sure that the RexCore is running on the machine with the given IP address? Try to execute following command:</p>
<pre><code>sudo systemctl status rexcore
<p dir="auto">Note: The ports mentioned above are valid just for default settings. All ports can be configured via <em>rexcore.cfg</em> file - for more details see:<a href="https://www.rexygen.com/doc/ENGLISH/MANUALS/RexCore/RexCore_ENG.html#x1-50002.2">https://www.rexygen.com/doc/ENGLISH/MANUALS/RexCore/RexCore_ENG.html#x1-50002.2</a></p>
]]></description><link>https://forum.rexygen.com/post/684</link><guid isPermaLink="true">https://forum.rexygen.com/post/684</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Thu, 07 Jan 2021 20:59:15 GMT</pubDate></item></channel></rss>
