<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ALB, ALBI, ALN, ALNI , .... alarm functions have no delay function]]></title><description><![CDATA[<p dir="auto">Would it be possible to create a delayON and delayOFF function for the alarm function blocks?</p>
<p dir="auto">I'm trying to make a workaround but this is quite cumbersome if you want to use all the other benefits of using the alarm blocks, especially for analog values.</p>
]]></description><link>https://forum.rexygen.com/topic/186/alb-albi-aln-alni-alarm-functions-have-no-delay-function</link><generator>RSS for Node</generator><lastBuildDate>Mon, 10 Aug 2026 23:32:42 GMT</lastBuildDate><atom:link href="https://forum.rexygen.com/topic/186.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 12 Jan 2021 10:23:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ALB, ALBI, ALN, ALNI , .... alarm functions have no delay function on Thu, 21 Jan 2021 08:12:55 GMT]]></title><description><![CDATA[<p dir="auto">Hi Kris,</p>
<p dir="auto">one more thing - did you try to use ARS function block? <a href="https://www.rexygen.com/doc/ENGLISH/MANUALS/BRef/ARS.html">https://www.rexygen.com/doc/ENGLISH/MANUALS/BRef/ARS.html</a></p>
<p dir="auto">It might help you.</p>
]]></description><link>https://forum.rexygen.com/post/745</link><guid isPermaLink="true">https://forum.rexygen.com/post/745</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Thu, 21 Jan 2021 08:12:55 GMT</pubDate></item><item><title><![CDATA[Reply to ALB, ALBI, ALN, ALNI , .... alarm functions have no delay function on Mon, 18 Jan 2021 11:26:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/185">@Apollo</a> said in <a href="/post/720">ALB, ALBI, ALN, ALNI , .... alarm functions have no delay function</a>:</p>
<p dir="auto">Do you mean to set the parameters lvl1 and lvl2? Because when I do, I get the error message as described above.</p>
<p dir="auto">Yes, I meant this parameters. My suggestion was to change the levels in already running algorithm. E.g. when you expect engine to start, just change the levels to the values which won't produce any alarm. As soon as the engine is in running mode, switch the levels back.</p>
]]></description><link>https://forum.rexygen.com/post/729</link><guid isPermaLink="true">https://forum.rexygen.com/post/729</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Mon, 18 Jan 2021 11:26:30 GMT</pubDate></item><item><title><![CDATA[Reply to ALB, ALBI, ALN, ALNI , .... alarm functions have no delay function on Thu, 14 Jan 2021 15:18:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/5">@cechurat</a> said in <a href="/post/719">ALB, ALBI, ALN, ALNI , .... alarm functions have no delay function</a>:</p>
<li>interactive changing of the levels*</li>
<p dir="auto">Maybe I'll try the SRTF solution, could work.... or wait for a new version with the new feature  <img src="https://forum.rexygen.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=6d51e091ff9" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":-)" alt="🙂" /></p>
<p dir="auto">Grtz,</p>
<p dir="auto">Kris</p>
]]></description><link>https://forum.rexygen.com/post/720</link><guid isPermaLink="true">https://forum.rexygen.com/post/720</guid><dc:creator><![CDATA[Apollo]]></dc:creator><pubDate>Thu, 14 Jan 2021 15:18:42 GMT</pubDate></item><item><title><![CDATA[Reply to ALB, ALBI, ALN, ALNI , .... alarm functions have no delay function on Thu, 14 Jan 2021 11:58:12 GMT]]></title><description><![CDATA[<p dir="auto">Hi Kris,</p>
<p dir="auto">I have turned your post into feature request again. There are some possible workarounds:</p>
<li>interactive changing of the levels</li>
<li>disabling execution of the function block using SRTF (see doc: <a href="https://www.rexygen.com/doc/ENGLISH/MANUALS/BRef/SRTF.html#x19-180002">https://www.rexygen.com/doc/ENGLISH/MANUALS/BRef/SRTF.html#x19-180002</a>)</li>
]]></description><link>https://forum.rexygen.com/post/719</link><guid isPermaLink="true">https://forum.rexygen.com/post/719</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Thu, 14 Jan 2021 11:58:12 GMT</pubDate></item><item><title><![CDATA[Reply to ALB, ALBI, ALN, ALNI , .... alarm functions have no delay function on Wed, 13 Jan 2021 13:26:14 GMT]]></title><description><![CDATA[<p dir="auto">I haven't tried filtering yet, this could work but is more complex then just a simple delay (ON&amp;OFF).<br />
I have another related question. For the FB ALB, ALBI there is a 'men' input so you can disable the alarms. This feature is missing on the FB ALN, ALNI.</p>
<p dir="auto">Example: if you want to monitor the oil pressure from an engine it should be possible to disable/suppress the low pressure alarm while the engine is starting up and in shutdown as well.</p>
<p dir="auto">You have any idea how to solve this? I tried with setting parameter lvl1 to zero but this is not allowed (nor lvl 2, as described in the documentation)</p>
<p dir="auto"><img src="/assets/uploads/files/1610544042490-35e70244-f521-4d71-bb13-d4689e7d1cd8-image.png" alt="35e70244-f521-4d71-bb13-d4689e7d1cd8-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.rexygen.com/post/713</link><guid isPermaLink="true">https://forum.rexygen.com/post/713</guid><dc:creator><![CDATA[Apollo]]></dc:creator><pubDate>Wed, 13 Jan 2021 13:26:14 GMT</pubDate></item><item><title><![CDATA[Reply to ALB, ALBI, ALN, ALNI , .... alarm functions have no delay function on Wed, 13 Jan 2021 12:22:01 GMT]]></title><description><![CDATA[<p dir="auto">Hi Kris,</p>
<p dir="auto">thanks for youe explanation - now I understand correctly. I have generated a feature request for our developers.</p>
<p dir="auto">For now - did you try to apply some filtering to your measured signal? E.g. moving average filter (AVG) or SPIKE filter.</p>
<p dir="auto">Kind Regards,</p>
<p dir="auto">Tomas</p>
]]></description><link>https://forum.rexygen.com/post/711</link><guid isPermaLink="true">https://forum.rexygen.com/post/711</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Wed, 13 Jan 2021 12:22:01 GMT</pubDate></item><item><title><![CDATA[Reply to ALB, ALBI, ALN, ALNI , .... alarm functions have no delay function on Tue, 12 Jan 2021 12:54:22 GMT]]></title><description><![CDATA[<p dir="auto">Hi Tomas,</p>
<p dir="auto">If you have for example a fluctuating analog signal or a signal with peaks it might happen that the alarm is triggered for a very short time. This behavior is perhaps completely normal and you don't want it to trigger an alarm if the signal is not too high/low for x seconds.<br />
Or a low-level float in a gearbox to detect low oil level on a ship requires some delay, otherwise, it would regularly trigger an alarm when there is some bad weather ... <img src="https://forum.rexygen.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=6d51e091ff9" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":-)" alt="🙂" /></p>
<p dir="auto">For boolean type signals it isn't really a problem to add some logic but to keep all function blocks for the alarming alike it would be better to implement it also for the boolean ones.</p>
]]></description><link>https://forum.rexygen.com/post/699</link><guid isPermaLink="true">https://forum.rexygen.com/post/699</guid><dc:creator><![CDATA[Apollo]]></dc:creator><pubDate>Tue, 12 Jan 2021 12:54:22 GMT</pubDate></item><item><title><![CDATA[Reply to ALB, ALBI, ALN, ALNI , .... alarm functions have no delay function on Tue, 12 Jan 2021 12:41:55 GMT]]></title><description><![CDATA[<p dir="auto">Hi Kris,</p>
<p dir="auto">please, can you provide more details? What is expected/wanted behaviour?<br />
If I understand correctly you can connect TIMER FB with ALB(I) input and it should do the trick, right? Analog values can be a bit tricky...</p>
]]></description><link>https://forum.rexygen.com/post/697</link><guid isPermaLink="true">https://forum.rexygen.com/post/697</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Tue, 12 Jan 2021 12:41:55 GMT</pubDate></item></channel></rss>
