<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[ALBI FB inside SubSystem]]></title><description><![CDATA[<p dir="auto">While trying to create a new Subsystem to add some functionalities to an already existing alarming Function block (ALBI) I encountered problems with using declared parameters.</p>
<p dir="auto">I declared a 'word' for the archive parameter (arc) which is used for the FB ALBI found inside the newly created Subsystem.<br />
But once I click on the Inherit checkbox inside the ALBI FB the program throws an error and crashes (stops working and closes).<br />
<img src="/assets/uploads/files/1610521915834-2021-01-13-07_23_34-block-properties.png" alt="2021-01-13 07_23_34-Block properties.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">It seems that ALBI-FB is not using the value but the 'Parameter' name instead, which is an invalid value....just guessing.</p>
<p dir="auto">Update : tested with other FB and it seems related to the 'arc' parameter, it is not accepting an inherited parameter.</p>
]]></description><link>https://forum.rexygen.com/topic/192/albi-fb-inside-subsystem</link><generator>RSS for Node</generator><lastBuildDate>Mon, 12 Oct 2026 18:20:47 GMT</lastBuildDate><atom:link href="https://forum.rexygen.com/topic/192.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 13 Jan 2021 07:14:50 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to ALBI FB inside SubSystem on Mon, 18 Jan 2021 09:43:34 GMT]]></title><description><![CDATA[<p dir="auto">Hi Kris,<br />
I just want to let you know that we found a bug and included the fix in a future release.</p>
]]></description><link>https://forum.rexygen.com/post/727</link><guid isPermaLink="true">https://forum.rexygen.com/post/727</guid><dc:creator><![CDATA[reitinge]]></dc:creator><pubDate>Mon, 18 Jan 2021 09:43:34 GMT</pubDate></item><item><title><![CDATA[Reply to ALBI FB inside SubSystem on Wed, 13 Jan 2021 19:11:19 GMT]]></title><description><![CDATA[<p dir="auto">Hi Kris,<br />
thanks for reporting this bug. The same behaviour occurs to me. I'll send this error to developers.</p>
]]></description><link>https://forum.rexygen.com/post/714</link><guid isPermaLink="true">https://forum.rexygen.com/post/714</guid><dc:creator><![CDATA[reitinge]]></dc:creator><pubDate>Wed, 13 Jan 2021 19:11:19 GMT</pubDate></item></channel></rss>
