<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Use of local parameters in RexHMI Designer]]></title><description><![CDATA[<p dir="auto">Is there someone who can explain to me how to use the local parameter(s) which are used inside RexHMI Designer?</p>
<p dir="auto">I would like to hide/unhide a window by means of a button on the screen but somehow it is not working. Should all be assigned to 'L'? When to use the curly brackets?</p>
<p dir="auto">Has someone maybe a small example how to set this up?</p>
]]></description><link>https://forum.rexygen.com/topic/194/use-of-local-parameters-in-rexhmi-designer</link><generator>RSS for Node</generator><lastBuildDate>Sun, 18 Oct 2026 02:55:15 GMT</lastBuildDate><atom:link href="https://forum.rexygen.com/topic/194.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 15 Jan 2021 17:17:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Use of local parameters in RexHMI Designer on Wed, 20 Jan 2021 17:13:31 GMT]]></title><description><![CDATA[<p dir="auto">Thank you for the examples. I was trying to make use of the placeholders (like $T for example) which I completed at the end in the Connections tab.</p>
<p dir="auto">Now I got it working by only creating the local parameters (HIDE_WINDOW_A, HIDE_WINDOW_B, ...) and giving them a default value '0' in the connections table.<br />
Then in the button's and windows which are to be hidden I used these newly created local parameters directly. (instead of using the $T).<br />
And now it is working fine. :-)...  still don't know what I'm doing wrong when using the connections table....</p>
]]></description><link>https://forum.rexygen.com/post/742</link><guid isPermaLink="true">https://forum.rexygen.com/post/742</guid><dc:creator><![CDATA[Apollo]]></dc:creator><pubDate>Wed, 20 Jan 2021 17:13:31 GMT</pubDate></item><item><title><![CDATA[Reply to Use of local parameters in RexHMI Designer on Wed, 20 Jan 2021 14:58:33 GMT]]></title><description><![CDATA[<p dir="auto">Hi Kris,</p>
<p dir="auto">thanks for you feedback. I can see that our documentation is not enough. Please, see the example attached:<br />
<a href="/assets/uploads/files/1611154684564-0301_human_machine_interface_hmi.zip">0301_Human_Machine_Interface_HMI.zip</a></p>
<p dir="auto">Let me know if there is still missing something.</p>
]]></description><link>https://forum.rexygen.com/post/741</link><guid isPermaLink="true">https://forum.rexygen.com/post/741</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Wed, 20 Jan 2021 14:58:33 GMT</pubDate></item><item><title><![CDATA[Reply to Use of local parameters in RexHMI Designer on Wed, 20 Jan 2021 12:31:04 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/5">@cechurat</a></p>
<p dir="auto">Yes, I have seen this document but somehow I cannot get it working. After a while I started to create all kind of possibilities and none of them worked. The funny thing is that I already managed to do this in the past but I didn't saved it...<br />
<img src="https://forum.rexygen.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f615.png?v=6d51e091ff9" class="not-responsive emoji emoji-android emoji--confused" style="height:23px;width:auto;vertical-align:middle" title=":confused:" alt="😕" /></p>
<p dir="auto">So for the button I should use the alias HIDE (between curly brackets?) and is it  'W' or 'L'  ?<br />
And the object which's opacity needs to be changed is then also the alias HIDE, inbetween brackets and 'R'? Or is 'L'.<br />
Is it important in which order the parameters are assigned in this table?</p>
]]></description><link>https://forum.rexygen.com/post/739</link><guid isPermaLink="true">https://forum.rexygen.com/post/739</guid><dc:creator><![CDATA[Apollo]]></dc:creator><pubDate>Wed, 20 Jan 2021 12:31:04 GMT</pubDate></item><item><title><![CDATA[Reply to Use of local parameters in RexHMI Designer on Wed, 20 Jan 2021 12:01:01 GMT]]></title><description><![CDATA[<p dir="auto">Hi Kris,</p>
<p dir="auto">thanks for question. Did you look into the HMI docs? The Local items are mentioned here: <a href="https://www.rexygen.com/doc/ENGLISH/MANUALS/RexHMI/RexHMI_ENG.html#x1-120003.2.1">https://www.rexygen.com/doc/ENGLISH/MANUALS/RexHMI/RexHMI_ENG.html#x1-120003.2.1</a></p>
<p dir="auto">You just need to specify Alias (used in button as control and other components as HIDE parameter), Default value (Connection String column) and type = L - see the Figure 3.3 in above mentioned docs.</p>
<p dir="auto">Let me know if it helped.</p>
]]></description><link>https://forum.rexygen.com/post/737</link><guid isPermaLink="true">https://forum.rexygen.com/post/737</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Wed, 20 Jan 2021 12:01:01 GMT</pubDate></item><item><title><![CDATA[Reply to Use of local parameters in RexHMI Designer on Tue, 19 Jan 2021 07:31:31 GMT]]></title><description><![CDATA[<p dir="auto">Nobody with a working example how to implement a button on the HMIpage to toggle the visibility (opacity) of another object on the same page by means of a local parameter?</p>
]]></description><link>https://forum.rexygen.com/post/730</link><guid isPermaLink="true">https://forum.rexygen.com/post/730</guid><dc:creator><![CDATA[Apollo]]></dc:creator><pubDate>Tue, 19 Jan 2021 07:31:31 GMT</pubDate></item></channel></rss>
