<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Use of the &#x27;MTM__SlaveStation_Connected&#x27; signal.]]></title><description><![CDATA[<p dir="auto">We are using the 'MTM__SlaveStation_Connected' signal to detect if the Modbus communication is established but while everything seems to be working fine the output of this signal remains 'off'</p>
<p dir="auto"><img src="/assets/uploads/files/1612259817255-25fd26b5-bf77-44c1-8e7d-801215933ba1-image.png" alt="25fd26b5-bf77-44c1-8e7d-801215933ba1-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">The output of the 'Connecting' block is sometimes 'on'.</p>
<p dir="auto"><img src="/assets/uploads/files/1612259896027-ae4994a6-2a2c-4bcf-a655-523b64f8334c-image.png" alt="ae4994a6-2a2c-4bcf-a655-523b64f8334c-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I expected that the 'MTM__SlaveStation_Connected' signal would be 'steady-on' after the communication is established.</p>
<p dir="auto"><img src="/assets/uploads/files/1612259990291-b8800510-d2e8-4fc5-a22a-7cfb0365a7e7-image.png" alt="b8800510-d2e8-4fc5-a22a-7cfb0365a7e7-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.rexygen.com/topic/211/use-of-the-mtm__slavestation_connected-signal</link><generator>RSS for Node</generator><lastBuildDate>Sun, 16 Aug 2026 11:09:28 GMT</lastBuildDate><atom:link href="https://forum.rexygen.com/topic/211.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 02 Feb 2021 10:00:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Use of the &#x27;MTM__SlaveStation_Connected&#x27; signal. on Fri, 05 Feb 2021 11:49:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/5">@cechurat</a> said in <a href="/post/801">Use of the 'MTM__SlaveStation_Connected' signal.</a>:</p>
<p dir="auto">Status shows time to next reconnect in ms</p>
]]></description><link>https://forum.rexygen.com/post/804</link><guid isPermaLink="true">https://forum.rexygen.com/post/804</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Fri, 05 Feb 2021 11:49:12 GMT</pubDate></item><item><title><![CDATA[Reply to Use of the &#x27;MTM__SlaveStation_Connected&#x27; signal. on Fri, 05 Feb 2021 06:59:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/5">@cechurat</a></p>
<p dir="auto">Oops, my apologies for waisting your time.... stupid mistake, should have seen this. <img src="https://forum.rexygen.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f644.png?v=6d51e091ff9" class="not-responsive emoji emoji-android emoji--face_with_rolling_eyes" style="height:23px;width:auto;vertical-align:middle" title=":face_with_rolling_eyes:" alt="🙄" /></p>
<p dir="auto"><img src="/assets/uploads/files/1612508244534-8299515e-5cf2-4997-ac75-e0c3b96468b2-image.png" alt="8299515e-5cf2-4997-ac75-e0c3b96468b2-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Now it's working. BTW, how to interpret the Status value?</p>
]]></description><link>https://forum.rexygen.com/post/803</link><guid isPermaLink="true">https://forum.rexygen.com/post/803</guid><dc:creator><![CDATA[Apollo]]></dc:creator><pubDate>Fri, 05 Feb 2021 06:59:37 GMT</pubDate></item><item><title><![CDATA[Reply to Use of the &#x27;MTM__SlaveStation_Connected&#x27; signal. on Thu, 04 Feb 2021 20:18:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/185">@apollo</a> Hi Kris,</p>
<p dir="auto">thanks for the .rio file. It says that <em>MTM__Node0_temperature</em> is read from Slave <em>TS-SH-E397-01</em> however the signals <em>_Connected</em>, <em>_Connecting</em> and <em>_Status</em> refer to Slave <em>SDSSHE39706</em>, which is not up and running at the moment if I'm not mistaken. (and therefore Status shows time to next reconnect in <em>ms</em> and <em>_Connecting</em> is sometimes UP for a while (where while = response timeout))</p>
<p dir="auto">Just change the auxiliary flags to <em>MTM__TS-SH-E397-01_xxx</em> and you should be able to see relevant information about the connection to the Slave.</p>
<p dir="auto"><img src="/assets/uploads/files/1612469591737-d1d29e71-4588-4416-bbd4-7d20c7705527-image.png" alt="d1d29e71-4588-4416-bbd4-7d20c7705527-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.rexygen.com/post/801</link><guid isPermaLink="true">https://forum.rexygen.com/post/801</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Thu, 04 Feb 2021 20:18:33 GMT</pubDate></item><item><title><![CDATA[Reply to Use of the &#x27;MTM__SlaveStation_Connected&#x27; signal. on Thu, 04 Feb 2021 13:30:57 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/5">@cechurat</a> said in <a href="/post/797">Use of the 'MTM__SlaveStation_Connected' signal.</a>:</p>
<p dir="auto">Can you try to add <em>MTM__SDSSHE39706_Status</em> signal?</p>
<p dir="auto">It is showing a counter (15bit) which is running down, over and over.</p>
<p dir="auto"><img src="/assets/uploads/files/1612445443908-e4b8a9ce-554a-47d9-a259-71344ecfa7b7-image.png" alt="e4b8a9ce-554a-47d9-a259-71344ecfa7b7-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.rexygen.com/post/800</link><guid isPermaLink="true">https://forum.rexygen.com/post/800</guid><dc:creator><![CDATA[Apollo]]></dc:creator><pubDate>Thu, 04 Feb 2021 13:30:57 GMT</pubDate></item><item><title><![CDATA[Reply to Use of the &#x27;MTM__SlaveStation_Connected&#x27; signal. on Thu, 04 Feb 2021 13:24:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/5">@cechurat</a></p>
<p dir="auto">It is because the time is (or was) set at 5s but changing it to the default '0.00' doesn't change.</p>
<p dir="auto">I have now another slave online and this is working fine. But with this one, I'm only using holding registers while the other one is a mix ... see .rio file attached</p>
<p dir="auto"><a href="/assets/uploads/files/1612444970356-modbus_cfg.rio">modbus_cfg.rio</a></p>
]]></description><link>https://forum.rexygen.com/post/799</link><guid isPermaLink="true">https://forum.rexygen.com/post/799</guid><dc:creator><![CDATA[Apollo]]></dc:creator><pubDate>Thu, 04 Feb 2021 13:24:31 GMT</pubDate></item><item><title><![CDATA[Reply to Use of the &#x27;MTM__SlaveStation_Connected&#x27; signal. on Thu, 04 Feb 2021 10:57:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/185">@apollo</a> Hi Kris,</p>
<p dir="auto">thanks for the log. I don't see anything suspicious.<br />
Can you send me the .rio file of the MTM configuration?</p>
<p dir="auto">I noticed that the <em>_Fresh</em> signal is 3-4s - why does it take so long to refresh the value?</p>
]]></description><link>https://forum.rexygen.com/post/797</link><guid isPermaLink="true">https://forum.rexygen.com/post/797</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Thu, 04 Feb 2021 10:57:35 GMT</pubDate></item><item><title><![CDATA[Reply to Use of the &#x27;MTM__SlaveStation_Connected&#x27; signal. on Wed, 03 Feb 2021 11:16:12 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/5">@cechurat</a> Please find the logfiles below. I do have at the moment 8 Modbus slaves configured but which are not online yet. The one and only slave which is communicating is the one that is not showing 'on' when connected. Although the data is coming just fine.</p>
<p dir="auto"><a href="/assets/uploads/files/1612350882073-exportlog20210203.csv">exportLog20210203.csv</a></p>
]]></description><link>https://forum.rexygen.com/post/793</link><guid isPermaLink="true">https://forum.rexygen.com/post/793</guid><dc:creator><![CDATA[Apollo]]></dc:creator><pubDate>Wed, 03 Feb 2021 11:16:12 GMT</pubDate></item><item><title><![CDATA[Reply to Use of the &#x27;MTM__SlaveStation_Connected&#x27; signal. on Wed, 03 Feb 2021 08:04:00 GMT]]></title><description><![CDATA[<p dir="auto">Hi Kris,</p>
<p dir="auto">you are right about the expected behaviour of the "MTM_SlaveStation_Connected" signal.<br />
The behaviour you are facing can mean some failure in communication. Please, can you turn on all I/O driver diagnostic messages (see screenshot) and share a bit of the System Log with us?  (REXYGEN Studio -&gt; Target -&gt; Show System log -&gt; right click -&gt; Export Items -&gt; All items)</p>
<p dir="auto"><img src="/assets/uploads/files/1612339265056-37a4f61c-567c-41ea-b581-51a112c49dcd-image.png" alt="37a4f61c-567c-41ea-b581-51a112c49dcd-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.rexygen.com/post/789</link><guid isPermaLink="true">https://forum.rexygen.com/post/789</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Wed, 03 Feb 2021 08:04:00 GMT</pubDate></item></channel></rss>
