<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Color of HMI component with &#x27;Group Animation&#x27; not correct.]]></title><description><![CDATA[<p dir="auto">What could be the reason that the colors are different for two equal objects? for example in the lower image you can see the two yellow bargraphs on the left. The one from the 'Oil Press IN' has the correct color, the left one seems to be less bright. The same for the three purple ones on the right side, there it is the middle one which is normall.</p>
<p dir="auto"><img src="/assets/uploads/files/1614935501334-c0348084-553b-4350-ab53-1eb4969583e7-image.png" alt="c0348084-553b-4350-ab53-1eb4969583e7-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.rexygen.com/topic/225/color-of-hmi-component-with-group-animation-not-correct</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Apr 2026 06:33:43 GMT</lastBuildDate><atom:link href="https://forum.rexygen.com/topic/225.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 05 Mar 2021 09:47:50 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Color of HMI component with &#x27;Group Animation&#x27; not correct. on Fri, 12 Mar 2021 13:37:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/185">@apollo</a> I am glad that it is working.</p>
]]></description><link>https://forum.rexygen.com/post/880</link><guid isPermaLink="true">https://forum.rexygen.com/post/880</guid><dc:creator><![CDATA[ondrej_severa]]></dc:creator><pubDate>Fri, 12 Mar 2021 13:37:15 GMT</pubDate></item><item><title><![CDATA[Reply to Color of HMI component with &#x27;Group Animation&#x27; not correct. on Fri, 12 Mar 2021 13:36:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/3">@ondrej_severa</a> it is not a real problem if you take this into account before you start creating your HMI, not afterwards like I did. <img src="https://forum.rexygen.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=rfreqd0ultg" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":-)" alt="🙂" /></p>
<p dir="auto">But just putting some underscores in front of some alias' to bring them on top of the list and it all worked out fine.</p>
]]></description><link>https://forum.rexygen.com/post/879</link><guid isPermaLink="true">https://forum.rexygen.com/post/879</guid><dc:creator><![CDATA[Apollo]]></dc:creator><pubDate>Fri, 12 Mar 2021 13:36:05 GMT</pubDate></item><item><title><![CDATA[Reply to Color of HMI component with &#x27;Group Animation&#x27; not correct. on Fri, 12 Mar 2021 12:04:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/185">@apollo</a> Yes, I know this is inconvenient. We are aware of this limitation and will are planning to change it in the future.<br />
Kind regards<br />
Ondrej</p>
]]></description><link>https://forum.rexygen.com/post/878</link><guid isPermaLink="true">https://forum.rexygen.com/post/878</guid><dc:creator><![CDATA[ondrej_severa]]></dc:creator><pubDate>Fri, 12 Mar 2021 12:04:10 GMT</pubDate></item><item><title><![CDATA[Reply to Color of HMI component with &#x27;Group Animation&#x27; not correct. on Thu, 11 Mar 2021 15:29:07 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/185">@apollo</a> ...this might be the problem <img src="https://forum.rexygen.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f615.png?v=rfreqd0ultg" class="not-responsive emoji emoji-android emoji--confused" style="height:23px;width:auto;vertical-align:middle" title=":-/" alt="😕" /></p>
<p dir="auto"><img src="/assets/uploads/files/1615476538240-6cef7524-e398-4571-b124-b4f1d93c41f6-image.png" alt="6cef7524-e398-4571-b124-b4f1d93c41f6-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.rexygen.com/post/877</link><guid isPermaLink="true">https://forum.rexygen.com/post/877</guid><dc:creator><![CDATA[Apollo]]></dc:creator><pubDate>Thu, 11 Mar 2021 15:29:07 GMT</pubDate></item><item><title><![CDATA[Reply to Color of HMI component with &#x27;Group Animation&#x27; not correct. on Wed, 10 Mar 2021 15:33:11 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/3">@ondrej_severa</a> I used an AND function in the connection string, so if one of the two values which is used is not present the object might show up with a colour somewhere half between grey (when no value connected) and the chosen colour.</p>
]]></description><link>https://forum.rexygen.com/post/876</link><guid isPermaLink="true">https://forum.rexygen.com/post/876</guid><dc:creator><![CDATA[Apollo]]></dc:creator><pubDate>Wed, 10 Mar 2021 15:33:11 GMT</pubDate></item><item><title><![CDATA[Reply to Color of HMI component with &#x27;Group Animation&#x27; not correct. on Mon, 08 Mar 2021 12:40:57 GMT]]></title><description><![CDATA[<p dir="auto">Hello <a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/185">@apollo</a>,<br />
The <code>color</code> function in the <em>Group animation</em> component does color interpolation between the given colors. So this allows you to fluently change color eg. from cold to hot. This interpolation is done if the value of the data point for the color is not on the low or high limit.<br />
I check your SVGs but I am not able to tell if this is your case.</p>
Ondrej</p>
]]></description><link>https://forum.rexygen.com/post/873</link><guid isPermaLink="true">https://forum.rexygen.com/post/873</guid><dc:creator><![CDATA[ondrej_severa]]></dc:creator><pubDate>Mon, 08 Mar 2021 12:40:57 GMT</pubDate></item><item><title><![CDATA[Reply to Color of HMI component with &#x27;Group Animation&#x27; not correct. on Sun, 07 Mar 2021 07:27:36 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/5">@cechurat</a>  source file send by email.</p>
<p dir="auto">Did some testing in the meanwhile : if I isolate for example the 3 purple bargraphs and delete all the rest then the problem does not occur. Changing the dynamic data to a fixed value doesn't change the outcome, then the difference in colour remains.</p>
]]></description><link>https://forum.rexygen.com/post/866</link><guid isPermaLink="true">https://forum.rexygen.com/post/866</guid><dc:creator><![CDATA[Apollo]]></dc:creator><pubDate>Sun, 07 Mar 2021 07:27:36 GMT</pubDate></item><item><title><![CDATA[Reply to Color of HMI component with &#x27;Group Animation&#x27; not correct. on Fri, 05 Mar 2021 20:04:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/185">@apollo</a> Hi Kris,<br />
thanks for question. To be honest it is really hard to say anything without looking into the source .svg file. Can you share it with us?</p>
]]></description><link>https://forum.rexygen.com/post/864</link><guid isPermaLink="true">https://forum.rexygen.com/post/864</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Fri, 05 Mar 2021 20:04:01 GMT</pubDate></item></channel></rss>
