<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Crashing when polling rate too high from OPC UA client.]]></title><description><![CDATA[<p dir="auto">When the OPC UA client (Kepware) is polling the OPC UA server then the rexcore is crashing and there is no more communication possible anymore. (even downloading a new program or diagnostics isn't possible)</p>
<p dir="auto">It seems that it causes the rexcore to crash when the polling frequency is too high.</p>
]]></description><link>https://forum.rexygen.com/topic/229/crashing-when-polling-rate-too-high-from-opc-ua-client</link><generator>RSS for Node</generator><lastBuildDate>Thu, 16 Apr 2026 12:03:57 GMT</lastBuildDate><atom:link href="https://forum.rexygen.com/topic/229.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 13 Mar 2021 12:57:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Crashing when polling rate too high from OPC UA client. on Tue, 16 Mar 2021 05:58:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/5">@cechurat</a> I am not 100% sure. I am not in control of the PC that is running this Keptware software.</p>
<p dir="auto">I believe that it was originally set at 1Hz but I am not sure, but when it was set to 0,1Hz it was working fine.<br />
For the moment it is still crashing the application because I believe it is set at a too high polling rate again. (I assume....I am not in control and do have no access on this PC, so it's hard to verify if this is the real problem.)<br />
But if I change the port number of the OPC UA server to make sure nobody is polling the server then everything keeps running fine.</p>
<p dir="auto">It would be good that only the communication would stop and not the entire rexcore.</p>
<p dir="auto">I will send you a PM with the complete setup.</p>
]]></description><link>https://forum.rexygen.com/post/890</link><guid isPermaLink="true">https://forum.rexygen.com/post/890</guid><dc:creator><![CDATA[Apollo]]></dc:creator><pubDate>Tue, 16 Mar 2021 05:58:25 GMT</pubDate></item><item><title><![CDATA[Reply to Crashing when polling rate too high from OPC UA client. on Sun, 14 Mar 2021 20:46:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/185">@apollo</a> Hi Kris,</p>
<p dir="auto">thanks for this bug report. Please, what is the approx. polling frequency? How many items are you reading?</p>
]]></description><link>https://forum.rexygen.com/post/888</link><guid isPermaLink="true">https://forum.rexygen.com/post/888</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Sun, 14 Mar 2021 20:46:17 GMT</pubDate></item></channel></rss>
