<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[UniPi 1.1.]]></title><description><![CDATA[<p dir="auto">Hello.<br />
What could be wrong?<br />
If I connect 9V to terminals A2I+ and A2I-, there is no value on the UNP__AI2 flag.<br />
<img src="/assets/uploads/files/1624008057429-flag.png" alt="flag.png" class=" img-fluid img-markdown" /><br />
Thank You</p>
]]></description><link>https://forum.rexygen.com/topic/245/unipi-1-1</link><generator>RSS for Node</generator><lastBuildDate>Mon, 08 Jun 2026 08:48:08 GMT</lastBuildDate><atom:link href="https://forum.rexygen.com/topic/245.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 18 Jun 2021 09:23:20 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to UniPi 1.1. on Mon, 21 Jun 2021 12:12:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/307">@pancirm</a> Hi Michal,<br />
I just tested AI1 and AI2 on our UniPi v1.1 and REXYGEN 2.50.10.12481 and everything seems to work. Do you have the possibility to test the same configuration on a different UniPi 1.1? Alternatively, could you try to reinstall the current UniPi using the instructions from <a href="https://www.rexygen.com/doc/ENGLISH/MANUALS/RexygenGettingStarted_UniPi/RexygenGettingStarted_UniPi_ENG.html#x1-180003.1">here</a>? To install Rexygen with the UniPi 1.1 driver, I used the following instructions on a fresh raspberry image:</p>
<pre><code>wget -nc https://download.rexcontrols.com/scripts/rex-install-unipi1_1.sh
chmod +x rex-install-unipi1_1.sh
sudo ./rex-install-unipi1_1.sh
<p dir="auto">Jan</p>
]]></description><link>https://forum.rexygen.com/post/974</link><guid isPermaLink="true">https://forum.rexygen.com/post/974</guid><dc:creator><![CDATA[reitinge]]></dc:creator><pubDate>Mon, 21 Jun 2021 12:12:43 GMT</pubDate></item><item><title><![CDATA[Reply to UniPi 1.1. on Fri, 18 Jun 2021 14:28:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/133">@reitinge</a><br />
I use REXYGEN 2.50.10.12481.<br />
I have already tried it in the AI1 input and the result is the same. I assume that the jumpers have no effect on the analog input.<br />
Michal</p>
]]></description><link>https://forum.rexygen.com/post/973</link><guid isPermaLink="true">https://forum.rexygen.com/post/973</guid><dc:creator><![CDATA[pancirm]]></dc:creator><pubDate>Fri, 18 Jun 2021 14:28:42 GMT</pubDate></item><item><title><![CDATA[Reply to UniPi 1.1. on Fri, 18 Jun 2021 13:56:25 GMT]]></title><description><![CDATA[<p dir="auto">Dear <a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/307">@pancirm</a>,<br />
could you please try to connect the voltage to AI1 and read the UNP__AI1 value?  The value -NAN.00000000000 is strange, what version of REXYGEN do you use? I will try to reproduce your problem.</p>
]]></description><link>https://forum.rexygen.com/post/972</link><guid isPermaLink="true">https://forum.rexygen.com/post/972</guid><dc:creator><![CDATA[reitinge]]></dc:creator><pubDate>Fri, 18 Jun 2021 13:56:25 GMT</pubDate></item></channel></rss>
