<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Serial ports on Wago PFC200]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/25/wago-modbus-port-name-address-65535">Wago Modbus - Port name + Address &gt; 65535</a></p>
<p dir="auto">On the contrary to the serial port on the CPU module, which is handled by the Linux OS (and is therefore directly accessible from REXYGEN), the 750-652 serial module is not recognized by the Linux OS at all. That's why you do not see it from the command line interface (there is no /dev/tty* device as you mentioned).</p>
<p dir="auto">The 750-652 module is connected via KBus (the internal bus of Wago I/O) and is not supported in REXYGEN at all. The only possibility is to manually push data to and from the Process Image of the module, as described in Chapter 4 of the 750-652 module documentation. Find it at <a href="https://www.wago.com/global/i-o-systems/rs-232-485-serial-interface/p/750-652">https://www.wago.com/global/i-o-systems/rs-232-485-serial-interface/p/750-652</a></p>
<p dir="auto">I hate to say it, but using any Modbus TCP/RS485 transparent gateway will save you a lot of work.  Alternatively, you can even use Wago PFC100 (750-8102) for such a purpose.</p>
<p dir="auto">Hope this helps at least a bit.</p>
]]></description><link>https://forum.rexygen.com/topic/26/serial-ports-on-wago-pfc200</link><generator>RSS for Node</generator><lastBuildDate>Thu, 10 Sep 2026 10:36:27 GMT</lastBuildDate><atom:link href="https://forum.rexygen.com/topic/26.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 15 Apr 2019 21:51:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Serial ports on Wago PFC200 on Fri, 19 Apr 2019 20:21:19 GMT]]></title><description><![CDATA[<p dir="auto">Hi Jaroslav,</p>
<p dir="auto">That explains why i could not find it. I will look into a TCP version or another PLC with more serial ports.</p>
<p dir="auto">Thanks,<br />
Richard</p>
<p dir="auto">PS<br />
I now have a slightly used 750-652 for sale <img src="https://forum.rexygen.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f609.png?v=6d51e091ff9" class="not-responsive emoji emoji-android emoji--wink" style="height:23px;width:auto;vertical-align:middle" title=";)" alt="😉" /></p>
]]></description><link>https://forum.rexygen.com/post/66</link><guid isPermaLink="true">https://forum.rexygen.com/post/66</guid><dc:creator><![CDATA[rluteijn]]></dc:creator><pubDate>Fri, 19 Apr 2019 20:21:19 GMT</pubDate></item></channel></rss>
