<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[1-WIRE Temp sensor unstable reading]]></title><description><![CDATA[<p dir="auto">Hi All,</p>
<p dir="auto">I'm wondering why I have erratic changes in temperature readings. The readings can jump anywhere from 0.3 to 0.8 of a degree at a time within a second, then back again. I would assume a 1-wire sensor with a metal casing would be a stable thermal mass.</p>
<p dir="auto">What could cause them to be so unstable? I have the driver set to 200ms execution. Another thing to note is the unstable sensors are around 0-3°C, the stable ones are around 18-20°C</p>
]]></description><link>https://forum.rexygen.com/topic/30/1-wire-temp-sensor-unstable-reading</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 19:00:56 GMT</lastBuildDate><atom:link href="https://forum.rexygen.com/topic/30.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 29 Apr 2019 02:17:18 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 1-WIRE Temp sensor unstable reading on Mon, 27 May 2019 22:56:30 GMT]]></title><description><![CDATA[<p dir="auto">An update to the above. I'm now very sure I had a bad batch of sensors, it turns out I'm not alone. Over people have seen the same thing having bought sensors from certain websites.</p>
<p dir="auto">Be careful when buying 1-Wire sensors as it seems there are cheaper, not so reliable ones flooding the market.</p>
]]></description><link>https://forum.rexygen.com/post/102</link><guid isPermaLink="true">https://forum.rexygen.com/post/102</guid><dc:creator><![CDATA[MikeyH]]></dc:creator><pubDate>Mon, 27 May 2019 22:56:30 GMT</pubDate></item><item><title><![CDATA[Reply to 1-WIRE Temp sensor unstable reading on Mon, 06 May 2019 11:29:49 GMT]]></title><description><![CDATA[<p dir="auto">Hi Jaroslav,</p>
<p dir="auto">I only had 4 sensors, and I am using the Monarco hat. The sensor cables are all 1.5m long is a star formation.</p>
<p dir="auto">I have ordered more as I think I had a bad batch. I have issues with the same sensors not working after a power loss.</p>
<p dir="auto">I will let you know more once I have tried the new sensors.</p>
]]></description><link>https://forum.rexygen.com/post/87</link><guid isPermaLink="true">https://forum.rexygen.com/post/87</guid><dc:creator><![CDATA[MikeyH]]></dc:creator><pubDate>Mon, 06 May 2019 11:29:49 GMT</pubDate></item><item><title><![CDATA[Reply to 1-WIRE Temp sensor unstable reading on Tue, 30 Apr 2019 08:16:45 GMT]]></title><description><![CDATA[<p dir="auto">Hi Mike,<br />
never heard of such a problem. Please provide more information, namely:</p>
<li>What hardware are you using as the 1-Wire master? Monarco HAT?</li>
<li>How many sensors in total are you using?</li>
<li>How long is the wiring?</li>
<li>Can you try swapping the temperature probes?</li>
<li>Does the problem persist if you use fewer sensors? E.g. removing the stable ones temporarily.</li>
<li>How often does this happen?</li>
<li>Do you have a time plot showing the reported problem?</li>
<li>Any errors in the System log?</li>
]]></description><link>https://forum.rexygen.com/post/78</link><guid isPermaLink="true">https://forum.rexygen.com/post/78</guid><dc:creator><![CDATA[jaroslav_sobota]]></dc:creator><pubDate>Tue, 30 Apr 2019 08:16:45 GMT</pubDate></item></channel></rss>
