<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Power Supply Voltage]]></title><description><![CDATA[<p dir="auto">Hi All,</p>
<p dir="auto">From within REXYGEN on the Monarco HAT. Can you sample/read the supply voltage to the HAT in anyway?</p>
]]></description><link>https://forum.rexygen.com/topic/32/power-supply-voltage</link><generator>RSS for Node</generator><lastBuildDate>Tue, 10 Nov 2026 20:57:40 GMT</lastBuildDate><atom:link href="https://forum.rexygen.com/topic/32.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 04 May 2019 00:13:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Power Supply Voltage on Mon, 06 May 2019 11:29:41 GMT]]></title><description><![CDATA[<p dir="auto">Hi Mike,<br />
thanks for clarification. I have no experience with that, but the <a href="https://www.maximintegrated.com/products/MAX17215">Maxim MAX1721x with 1-Wire interface</a> seems to be ideal for such a project with the Monarco HAT.</p>
]]></description><link>https://forum.rexygen.com/post/86</link><guid isPermaLink="true">https://forum.rexygen.com/post/86</guid><dc:creator><![CDATA[jaroslav_sobota]]></dc:creator><pubDate>Mon, 06 May 2019 11:29:41 GMT</pubDate></item><item><title><![CDATA[Reply to Power Supply Voltage on Mon, 06 May 2019 11:21:22 GMT]]></title><description><![CDATA[<p dir="auto">Hi Jaroslav,</p>
<p dir="auto">The reason is for battery monitoring. Using an external sensor is fine. Just wondering if the hat had some way of internal measurement.</p>
<p dir="auto">I will need it to work out battery charge etc.</p>
]]></description><link>https://forum.rexygen.com/post/85</link><guid isPermaLink="true">https://forum.rexygen.com/post/85</guid><dc:creator><![CDATA[MikeyH]]></dc:creator><pubDate>Mon, 06 May 2019 11:21:22 GMT</pubDate></item><item><title><![CDATA[Reply to Power Supply Voltage on Mon, 06 May 2019 06:14:45 GMT]]></title><description><![CDATA[<p dir="auto">Hi Mike,<br />
thanks for the question. This is not possible, the supply voltage is not connected to any ADC converter. The only option is to use external voltage dividers and bring it to one of the analog inputs of the Monarco HAT.</p>
<p dir="auto">What is the motivation for such a request? Some battery/solar-powered application?</p>
]]></description><link>https://forum.rexygen.com/post/83</link><guid isPermaLink="true">https://forum.rexygen.com/post/83</guid><dc:creator><![CDATA[jaroslav_sobota]]></dc:creator><pubDate>Mon, 06 May 2019 06:14:45 GMT</pubDate></item></channel></rss>
