<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Fluctuating value]]></title><description><![CDATA[<p dir="auto">Hello I have a problem with analog temperature measurement. The value fluctuates too much, see image Tmp.png. How to stabilize this value?<br />
Thank you Michal<br />
<img src="/assets/uploads/files/1661696734172-tmp-resized.png" alt="Tmp.png" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1661696744665-mcp3208.png" alt="mcp3208.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.rexygen.com/topic/329/fluctuating-value</link><generator>RSS for Node</generator><lastBuildDate>Mon, 07 Sep 2026 06:05:18 GMT</lastBuildDate><atom:link href="https://forum.rexygen.com/topic/329.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 28 Aug 2022 14:27:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Fluctuating value on Mon, 29 Aug 2022 05:13:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/307">@pancirm</a> Hi Michal,</p>
<p dir="auto">Thanks for your posts. There is no one-shot solution for general filtering applications so playing around with AVG function block would be the approach I would recommend. There are also some filters which can be used - low-pass, band-pass, and spike.</p>
]]></description><link>https://forum.rexygen.com/post/1161</link><guid isPermaLink="true">https://forum.rexygen.com/post/1161</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Mon, 29 Aug 2022 05:13:21 GMT</pubDate></item><item><title><![CDATA[Reply to Fluctuating value on Sun, 28 Aug 2022 20:02:11 GMT]]></title><description><![CDATA[<p dir="auto">So I solved it with the AVG block, but I had to play with the tick settings of the whole algorithm, the number of samples and the range of fluctuating values over time.</p>
]]></description><link>https://forum.rexygen.com/post/1159</link><guid isPermaLink="true">https://forum.rexygen.com/post/1159</guid><dc:creator><![CDATA[pancirm]]></dc:creator><pubDate>Sun, 28 Aug 2022 20:02:11 GMT</pubDate></item></channel></rss>
