<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Change IP address for ModBus TCP&#x2F;IP from HMI]]></title><description><![CDATA[<p dir="auto">I'm wondering if there is a possibility to enter a new IP address for a device that is connected using Modbus Master TCP/IP.<br />
<img src="/assets/uploads/files/1666795821279-ip_address_master_modbus_tcpip.png" alt="IP_address_Master_Modbus_TCPIP.PNG" class=" img-fluid img-markdown" /><br />
If I now want to change the IP address I have to change it in the configuration under MTM driver and have to load the entire project again to the raspberry.<br />
If it simply can be done from out of the HMI it would be much easier for the operator.</p>
<p dir="auto">Looking forward for feedback on this.</p>
]]></description><link>https://forum.rexygen.com/topic/341/change-ip-address-for-modbus-tcp-ip-from-hmi</link><generator>RSS for Node</generator><lastBuildDate>Mon, 08 Jun 2026 08:37:44 GMT</lastBuildDate><atom:link href="https://forum.rexygen.com/topic/341.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 26 Oct 2022 14:51:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Change IP address for ModBus TCP&#x2F;IP from HMI on Tue, 01 Nov 2022 07:38:10 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/17">@rexpeter</a> Hi Peter,</p>
<p dir="auto">I have an update on your Topic. It is possible to change the Slave IP address by configuring "Address" parameter (e.g. GoTo flag "MTM__1_Address" in your case).</p>
<p dir="auto"><img src="/assets/uploads/files/1667288138087-f8a090e9-9a03-4eec-9c12-a64115101392-image.png" alt="f8a090e9-9a03-4eec-9c12-a64115101392-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.rexygen.com/post/1198</link><guid isPermaLink="true">https://forum.rexygen.com/post/1198</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Tue, 01 Nov 2022 07:38:10 GMT</pubDate></item><item><title><![CDATA[Reply to Change IP address for ModBus TCP&#x2F;IP from HMI on Thu, 27 Oct 2022 09:05:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/17">@rexpeter</a> Hi Peter, Thank you for your question. Welcome back!</p>
<p dir="auto">The answer to your question is in Modbus Driver Documentation within Chapter 3.4: <a href="https://www.rexygen.com/doc/ENGLISH/MANUALS/MbDrv/MbDrv_ENG.html#x1-200003.4">https://www.rexygen.com/doc/ENGLISH/MANUALS/MbDrv/MbDrv_ENG.html#x1-200003.4</a></p>
<p dir="auto">It is possible to change the "Slave" parameter of selected Item (e.g. GoTo flag MTM__Adam_9_Slave). However, all the Slave addresses must be declared prior to compilation. Afterwards, you can switch the reference to the Slave at each Item (by introducing the GoTo flag mentioned above).</p>
<p dir="auto">I hope it helps.</p>
<p dir="auto">Let me know if it works for you.</p>
]]></description><link>https://forum.rexygen.com/post/1197</link><guid isPermaLink="true">https://forum.rexygen.com/post/1197</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Thu, 27 Oct 2022 09:05:43 GMT</pubDate></item></channel></rss>
