<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Writing once a single value to a register]]></title><description><![CDATA[<p dir="auto">I"m trying to communicate with a Beckhoff BK9000 bus coupler and to reset the watchdog timer I need to send consecutively the values  0xBECF and 0xAFFE to a single register.</p>
<p dir="auto">I only want to send this reset command when the watchdog timer elapsed due to some problem....</p>
<p dir="auto">I'm not sure if this is possible with Rexygen......</p>
]]></description><link>https://forum.rexygen.com/topic/41/writing-once-a-single-value-to-a-register</link><generator>RSS for Node</generator><lastBuildDate>Wed, 20 May 2026 13:13:45 GMT</lastBuildDate><atom:link href="https://forum.rexygen.com/topic/41.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 09 Jun 2019 18:30:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Writing once a single value to a register on Fri, 14 Jun 2019 06:36:07 GMT]]></title><description><![CDATA[<p dir="auto">Hi Scoobsalamander,</p>
<p dir="auto">glad I could help. You are right, I didn't take to count the timing. Good luck with your project!</p>
]]></description><link>https://forum.rexygen.com/post/115</link><guid isPermaLink="true">https://forum.rexygen.com/post/115</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Fri, 14 Jun 2019 06:36:07 GMT</pubDate></item><item><title><![CDATA[Reply to Writing once a single value to a register on Thu, 13 Jun 2019 19:19:14 GMT]]></title><description><![CDATA[<p dir="auto">Hi Tomas,</p>
<p dir="auto">Thanks, this is indeed a working solution. I only needed to slow down the messages to 1 per second, which is still fine.</p>
]]></description><link>https://forum.rexygen.com/post/114</link><guid isPermaLink="true">https://forum.rexygen.com/post/114</guid><dc:creator><![CDATA[Scoobsalamander]]></dc:creator><pubDate>Thu, 13 Jun 2019 19:19:14 GMT</pubDate></item><item><title><![CDATA[Reply to Writing once a single value to a register on Wed, 12 Jun 2019 06:45:55 GMT]]></title><description><![CDATA[<p dir="auto">Hi Scoobsalamander,</p>
<p dir="auto">thanks for your question. If I understand correctly the solution can look like:</p>
<p dir="auto"><img src="/assets/uploads/files/1560321843739-911a57a2-c6a3-4ebd-8885-c9f09d5ac2d7-image.png" alt="0_1560321840892_911a57a2-c6a3-4ebd-8885-c9f09d5ac2d7-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Sample source file: <a href="/assets/uploads/files/1560321853509-beckhoff_resetwatchdog.mdl">Beckhoff_resetWatchdog.mdl</a></p>
]]></description><link>https://forum.rexygen.com/post/113</link><guid isPermaLink="true">https://forum.rexygen.com/post/113</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Wed, 12 Jun 2019 06:45:55 GMT</pubDate></item></channel></rss>
