<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Replacing typed characters for &quot;***&quot; while typing a password]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">I"m wondering if there is an example how you can replace characters when typing. Like you do for many websites when entering a password.<br />
So I want to use a typed string from the HMI in the "task" block, but want to replace the typed characters with "***" characters.</p>
<p dir="auto">Looking forward for feedback on this.</p>
Peter</p>
]]></description><link>https://forum.rexygen.com/topic/49/replacing-typed-characters-for-while-typing-a-password</link><generator>RSS for Node</generator><lastBuildDate>Mon, 08 Jun 2026 07:58:03 GMT</lastBuildDate><atom:link href="https://forum.rexygen.com/topic/49.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 21 Jul 2019 18:25:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Replacing typed characters for &quot;***&quot; while typing a password on Wed, 08 Jul 2020 11:51:58 GMT]]></title><description><![CDATA[<p dir="auto">Hi Tomas,</p>
<p dir="auto">Great, this works. Thanks a lot for the feedback and to get it going!</p>
<p dir="auto">Peter</p>
]]></description><link>https://forum.rexygen.com/post/440</link><guid isPermaLink="true">https://forum.rexygen.com/post/440</guid><dc:creator><![CDATA[RexPeter]]></dc:creator><pubDate>Wed, 08 Jul 2020 11:51:58 GMT</pubDate></item><item><title><![CDATA[Reply to Replacing typed characters for &quot;***&quot; while typing a password on Wed, 08 Jul 2020 11:24:35 GMT]]></title><description><![CDATA[<p dir="auto">Hi Peter,</p>
<p dir="auto">the HTTPS server is enabled by default on port 8009 - there is no need to change the rexcore.cfg unless you want to change the port.</p>
<p dir="auto">The HMI should be accessible at</p>
<pre><code>https://YOUR_RPI_IP:8009/
<p dir="auto">Be sure to write explicitly <strong>https</strong> and the ending <strong>/</strong>.</p>
]]></description><link>https://forum.rexygen.com/post/438</link><guid isPermaLink="true">https://forum.rexygen.com/post/438</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Wed, 08 Jul 2020 11:24:35 GMT</pubDate></item><item><title><![CDATA[Reply to Replacing typed characters for &quot;***&quot; while typing a password on Tue, 07 Jul 2020 15:03:36 GMT]]></title><description><![CDATA[<p dir="auto">Hi Ondrej,</p>
<p dir="auto">I tried also to enable the HTTPS protocol, but don't succeed.<br />
According to the information I should change the rexcore.cfg file.</p>
<p dir="auto"><img src="/assets/uploads/files/1594134032357-rexcore_file_setting.png" alt="rexcore_file_setting.PNG" class=" img-fluid img-markdown" /></p>
<p dir="auto">So based on the description "option=value" I would expect this should be working.<br />
<img src="/assets/uploads/files/1594134098322-https_connection_setting.png" alt="HTTPS_connection_setting.PNG" class=" img-fluid img-markdown" /></p>
<p dir="auto">But this last line in the file is NOT doing the job. I have (after reboot) no connection to the HMI on port 8009.</p>
<p dir="auto">Or is there anything else that needs to be enabled to achieve this?</p>
Peter</p>
]]></description><link>https://forum.rexygen.com/post/436</link><guid isPermaLink="true">https://forum.rexygen.com/post/436</guid><dc:creator><![CDATA[RexPeter]]></dc:creator><pubDate>Tue, 07 Jul 2020 15:03:36 GMT</pubDate></item><item><title><![CDATA[Reply to Replacing typed characters for &quot;***&quot; while typing a password on Fri, 26 Jun 2020 14:26:43 GMT]]></title><description><![CDATA[<p dir="auto">Hello Ondrej,</p>
<p dir="auto">This is really nice!<br />
Looks great, thanks a lot!</p>
Peter</p>
]]></description><link>https://forum.rexygen.com/post/428</link><guid isPermaLink="true">https://forum.rexygen.com/post/428</guid><dc:creator><![CDATA[RexPeter]]></dc:creator><pubDate>Fri, 26 Jun 2020 14:26:43 GMT</pubDate></item><item><title><![CDATA[Reply to Replacing typed characters for &quot;***&quot; while typing a password on Thu, 25 Jun 2020 06:44:19 GMT]]></title><description><![CDATA[<p dir="auto">Yes this feature is already included in your pre-release version. Just use <em>HMI Designer</em> and use Input component. You have to change <code>format</code> to <code>password</code>.<br />
Best regards<br />
Ondrej</p>
]]></description><link>https://forum.rexygen.com/post/419</link><guid isPermaLink="true">https://forum.rexygen.com/post/419</guid><dc:creator><![CDATA[ondrej_severa]]></dc:creator><pubDate>Thu, 25 Jun 2020 06:44:19 GMT</pubDate></item><item><title><![CDATA[Reply to Replacing typed characters for &quot;***&quot; while typing a password on Wed, 24 Jun 2020 12:27:40 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/3">@ondrej_severa</a></p>
<p dir="auto">That sounds promising and I like to try it out!<br />
I am currently already on a pre-released Version V 2.50.10.11464.<br />
Or is it also available in that release already?</p>
Peter</p>
]]></description><link>https://forum.rexygen.com/post/417</link><guid isPermaLink="true">https://forum.rexygen.com/post/417</guid><dc:creator><![CDATA[RexPeter]]></dc:creator><pubDate>Wed, 24 Jun 2020 12:27:40 GMT</pubDate></item><item><title><![CDATA[Reply to Replacing typed characters for &quot;***&quot; while typing a password on Wed, 24 Jun 2020 08:29:31 GMT]]></title><description><![CDATA[<p dir="auto">Hi Peter,</p>
<p dir="auto">the feature is now available in pre-release version 2.50.10-r5. Do you want to try it out or better wait for public release version?</p>
<p dir="auto">Regards, Ondrej</p>
]]></description><link>https://forum.rexygen.com/post/416</link><guid isPermaLink="true">https://forum.rexygen.com/post/416</guid><dc:creator><![CDATA[ondrej_severa]]></dc:creator><pubDate>Wed, 24 Jun 2020 08:29:31 GMT</pubDate></item><item><title><![CDATA[Reply to Replacing typed characters for &quot;***&quot; while typing a password on Tue, 23 Jun 2020 19:27:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/3">@ondrej_severa</a><br />
Hi Ondrej,</p>
<p dir="auto">Is there any news on this new feature spoken about in the thread before (replacing characters for “*” when entering a “password”?<br />
My intension is using that for the HMI page to enter for instance a configuration page that normally should not be meshed up by anyone.</p>
<p dir="auto">Thanks in advance,<br />
Best regards,<br />
Peter</p>
]]></description><link>https://forum.rexygen.com/post/415</link><guid isPermaLink="true">https://forum.rexygen.com/post/415</guid><dc:creator><![CDATA[RexPeter]]></dc:creator><pubDate>Tue, 23 Jun 2020 19:27:30 GMT</pubDate></item><item><title><![CDATA[Reply to Replacing typed characters for &quot;***&quot; while typing a password on Sat, 27 Jul 2019 10:24:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/3">@ondrej_severa</a><br />
Thanks a lot for your feedback and looking forward for the update to make this possible.<br />
Thanks for the tip about https usages!</p>
Peter</p>
]]></description><link>https://forum.rexygen.com/post/141</link><guid isPermaLink="true">https://forum.rexygen.com/post/141</guid><dc:creator><![CDATA[RexPeter]]></dc:creator><pubDate>Sat, 27 Jul 2019 10:24:17 GMT</pubDate></item><item><title><![CDATA[Reply to Replacing typed characters for &quot;***&quot; while typing a password on Wed, 24 Jul 2019 17:09:19 GMT]]></title><description><![CDATA[<p dir="auto">Hello Peter,<br />
so far this feature is not available yet, but it will be soon. Just little recommendation. If you are about to use passwords in your HMI I strongly recommend to switch from HTTP to HTTPS protocol.<br />
Just visit the https//: 127.0.0.1:<strong>8009</strong> (mind the different port) and your communication between web browser and REGYGEN web server will be encrypted.</p>
Ondrej</p>
]]></description><link>https://forum.rexygen.com/post/140</link><guid isPermaLink="true">https://forum.rexygen.com/post/140</guid><dc:creator><![CDATA[ondrej_severa]]></dc:creator><pubDate>Wed, 24 Jul 2019 17:09:19 GMT</pubDate></item></channel></rss>
