<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[got some errors during installing REXYGEN for UniPi]]></title><description><![CDATA[<p dir="auto">Re: <a href="/topic/50/new-raspbian-version-buster-was-released-this-month">New Raspbian Version Buster was released this month</a></p>
<p dir="auto">Followed the installation for UniPi and got some errors:</p>
<p dir="auto">Setting up owserver (3.2p3+dfsg1-2) ...<br />
Job for owserver.service failed because the service did not take the steps required by its unit configuration.<br />
See "systemctl status owserver.service" and "journalctl -xe" for details.<br />
invoke-rc.d: initscript owserver, action "start" failed.<br />
● owserver.service - Backend server for 1-wire control<br />
Loaded: loaded (/lib/systemd/system/owserver.service; disabled; vendor preset: enabled)<br />
Active: activating (auto-restart) (Result: protocol) since Wed 2019-07-31 21:48:45 CEST; 231ms ago<br />
Docs: man:owserver(1)<br />
Process: 662 ExecStart=/usr/bin/owserver -c /etc/owfs.conf (code=exited, status=0/SUCCESS)<br />
Main PID: 662 (code=exited, status=0/SUCCESS)</p>
<p dir="auto">Jul 31 21:48:45 raspberrypi03 systemd[1]: owserver.service: Service RestartSec=100ms expired, scheduling restart.<br />
Jul 31 21:48:45 raspberrypi03 systemd[1]: owserver.service: Scheduled restart job, restart counter is at 1.<br />
Jul 31 21:48:46 raspberrypi03 systemd[1]: Stopped Backend server for 1-wire control.<br />
dpkg: error processing package owserver (--configure):<br />
installed owserver package post-installation script subprocess returned error exit status 1<br />
dpkg: dependency problems prevent configuration of rex-owsdrvt:<br />
rex-owsdrvt depends on owserver; however:<br />
Package owserver is not configured yet.</p>
<p dir="auto">dpkg: error processing package rex-owsdrvt (--configure):<br />
dependency problems - leaving unconfigured<br />
dpkg: dependency problems prevent configuration of rexygen-runtime:<br />
rexygen-runtime depends on rex-owsdrvt (= 2.50.9-10679~Raspbian~stretch); however:<br />
Package rex-owsdrvt is not configured yet.</p>
<p dir="auto">dpkg: error processing package rexygen-runtime (--configure):<br />
Errors were encountered while processing:<br />
owserver<br />
rex-owsdrvt<br />
rexygen-runtime<br />
E: Sub-process /usr/bin/dpkg returned an error code (1)</p>
]]></description><link>https://forum.rexygen.com/topic/53/got-some-errors-during-installing-rexygen-for-unipi</link><generator>RSS for Node</generator><lastBuildDate>Thu, 10 Sep 2026 10:14:23 GMT</lastBuildDate><atom:link href="https://forum.rexygen.com/topic/53.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 31 Jul 2019 19:53:47 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to got some errors during installing REXYGEN for UniPi on Fri, 09 Aug 2019 20:16:32 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/10">@jaroslav_sobota</a></p>
<p dir="auto">After installing Buster Lite Image I made manual install of owserver.<br />
sudo apt install owserer<br />
During that install I got the same error messages.<br />
Reboot and install rex with unipi script.<br />
Everything was installed without any error.<br />
Raspi is up and running without any issues.</p>
]]></description><link>https://forum.rexygen.com/post/171</link><guid isPermaLink="true">https://forum.rexygen.com/post/171</guid><dc:creator><![CDATA[gninaus]]></dc:creator><pubDate>Fri, 09 Aug 2019 20:16:32 GMT</pubDate></item><item><title><![CDATA[Reply to got some errors during installing REXYGEN for UniPi on Thu, 08 Aug 2019 11:54:40 GMT]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I am not able to reproduce the problem. With the <a href="https://github.com/rexcontrols/rex-install-rpi">latest installation scripts</a>, everything gets installed correctly.</p>
<p dir="auto">Any updates on your side?</p>
]]></description><link>https://forum.rexygen.com/post/164</link><guid isPermaLink="true">https://forum.rexygen.com/post/164</guid><dc:creator><![CDATA[jaroslav_sobota]]></dc:creator><pubDate>Thu, 08 Aug 2019 11:54:40 GMT</pubDate></item><item><title><![CDATA[Reply to got some errors during installing REXYGEN for UniPi on Fri, 02 Aug 2019 15:24:44 GMT]]></title><description><![CDATA[<p dir="auto">Hi,<br />
thanks for reporting this. The problem is with owserver installation in Buster.</p>
<p dir="auto">Can you try running</p>
<pre><code>sudo dpkg --configure -a
<p dir="auto">We'll definitely try to reproduce the problem here on our testbench in the next week. Will get back to you.</p>
]]></description><link>https://forum.rexygen.com/post/149</link><guid isPermaLink="true">https://forum.rexygen.com/post/149</guid><dc:creator><![CDATA[jaroslav_sobota]]></dc:creator><pubDate>Fri, 02 Aug 2019 15:24:44 GMT</pubDate></item></channel></rss>
