<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Custom display component]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">You described a process for custom switch component.</p>
<p dir="auto">But, is it applicable for custom displays as gauges or specific links lines ?</p>
<p dir="auto">Here is a gauge I would like to realise,</p>
<p dir="auto">The rounded arc, could change color, with a variable value, and the center iron turn auround the arc with a specific angle.</p>
<p dir="auto">The center Iron could change color too.</p>
<p dir="auto">For exemple for a speed gauge.</p>
<p dir="auto">Many thanks any replies</p>
<p dir="auto"><img src="/assets/uploads/files/1717447580190-speed-gauge.png" alt="Speed gauge.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.rexygen.com/topic/585/custom-display-component</link><generator>RSS for Node</generator><lastBuildDate>Thu, 10 Sep 2026 10:06:27 GMT</lastBuildDate><atom:link href="https://forum.rexygen.com/topic/585.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 03 Jun 2024 20:47:06 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Custom display component on Mon, 24 Jun 2024 20:37:45 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/5">@cechurat</a></p>
<p dir="auto">Hello Tomas,</p>
<p dir="auto">After read and read again the first lines of the procedures,<br />
Unfortunately, I cannot arrive to register my component.</p>
<p dir="auto">If we take your "procedure note", in the exemple 0301-12,</p>
<p dir="auto">I would like to register my gauge,<br />
In first step I select my circle and needle as group of component.</p>
<p dir="auto">An error flag appear with this message :</p>
<p dir="auto"><img src="/assets/uploads/files/1719261344355-issue-flag.png" alt="Issue flag.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Does it mean I need a background square for my component ?</p>
<p dir="auto">In the procedure, at line 11, "check <em>external file</em> and close the dialog with <em>ok</em><br />
Does it mean in group animation window : Ticking "import content of the group from external file"</p>
<p dir="auto">If yes, I have some troubles with "import content", meaning for me we not export the selection, but rather the reverse.</p>
<p dir="auto">I tried to redesign the component on a blank page with a square as a background with the circle and the needle, and repeat the procedure.<br />
And tick external file square.</p>
<p dir="auto">In the procedure, at line 15, "open the extenal file and had some content"</p>
<p dir="auto">When we tick this case and close the group box by ok, it register the component automaticly ?</p>
<p dir="auto">But where ?</p>
<p dir="auto">I try have a standalone component which could use on any independant project.</p>
<p dir="auto">Does I need to apply rather the procedure for a custom button explained at the top of the forum ?</p>
<p dir="auto">Can you help me</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.rexygen.com/post/1612</link><guid isPermaLink="true">https://forum.rexygen.com/post/1612</guid><dc:creator><![CDATA[Tourneur]]></dc:creator><pubDate>Mon, 24 Jun 2024 20:37:45 GMT</pubDate></item><item><title><![CDATA[Reply to Custom display component on Fri, 21 Jun 2024 12:15:44 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/1301">@Tourneur</a> Hi,</p>
<p dir="auto">glad you made it work!</p>
<p dir="auto">Yes, it is possible to make a custom component (separate SVG file). For more details see example "0301-12 HMI with External file".</p>
]]></description><link>https://forum.rexygen.com/post/1610</link><guid isPermaLink="true">https://forum.rexygen.com/post/1610</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Fri, 21 Jun 2024 12:15:44 GMT</pubDate></item><item><title><![CDATA[Reply to Custom display component on Wed, 19 Jun 2024 22:23:14 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/5">@cechurat</a></p>
<p dir="auto">Thanks in advance for the trick !</p>
<p dir="auto">My gauge start to look like the real one,<br />
With little bit difference like the color.</p>
<p dir="auto">I had fews setting with the starting angle, but with the bracket keys trick, it work so good !</p>
<p dir="auto">Thanks a lot for help !</p>
<p dir="auto">Now I have to reproduce it with the real colors and other parameters like circle colors change.</p>
<p dir="auto">Does it be possible to save this animation group as a custom component ?<br />
Or does I need to rebuilt it at everytime I require it ?</p>
<p dir="auto">Thanks again a lot Tomas !</p>
<p dir="auto"><img src="/assets/uploads/files/1718835731313-gauge.png" alt="Gauge.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.rexygen.com/post/1608</link><guid isPermaLink="true">https://forum.rexygen.com/post/1608</guid><dc:creator><![CDATA[Tourneur]]></dc:creator><pubDate>Wed, 19 Jun 2024 22:23:14 GMT</pubDate></item><item><title><![CDATA[Reply to Custom display component on Wed, 19 Jun 2024 07:18:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/1301">@Tourneur</a> Hi! What a progress - great!</p>
<p dir="auto">You just need to change the pivot point by means of the Inscape editor. Feel free to Google any Inkscape-related documentation on this (e.g. <a href="https://www.tutorviacomputer.com/inkscape/rotate-flip-objects/">https://www.tutorviacomputer.com/inkscape/rotate-flip-objects/</a>)</p>
<p dir="auto">Note: Once the object is "animated" by REXYGEN Extension I recommend you to delete the object, change the pivot point and make the animation again.</p>
<p dir="auto">Good luck!<br />
]]></description><link>https://forum.rexygen.com/post/1607</link><guid isPermaLink="true">https://forum.rexygen.com/post/1607</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Wed, 19 Jun 2024 07:18:50 GMT</pubDate></item><item><title><![CDATA[Reply to Custom display component on Tue, 18 Jun 2024 21:10:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/5">@cechurat</a></p>
<p dir="auto">Hello Cechurat,</p>
<p dir="auto">Quite good thing !</p>
<p dir="auto">First I could realize an analog control from HMI panel,<br />
And effectively, I succeeded to control line iron of my proper gauge.</p>
<p dir="auto">But, in my particular case,</p>
<p dir="auto">I would like to control the pivotation of the needle, with it end fixed on the center of the circle, like an watch clock needle.</p>
<p dir="auto">My actualy problem, is that the needle turn completly, like it center point is on the center of the line of needle.</p>
<p dir="auto">How could I change this pivot point ?<br />
Or let the one end fixed on a desired point ?</p>
<p dir="auto">I think you understood what I try to explain, but have a look on my picture :</p>
<p dir="auto">At 0 needle is not pivotate around the circle<br />
At 20 needle, normaly must pivotate at 20% around the circle, but here, you can see, needle turn around itself.</p>
<p dir="auto">Not my desired search...</p>
<p dir="auto"><img src="/assets/uploads/files/1718744888637-needle-at-0.png" alt="Needle at 0.png" class=" img-fluid img-markdown" /></p>
<p dir="auto"><img src="/assets/uploads/files/1718744920612-needle-at-20.png" alt="Needle at 20%.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.rexygen.com/post/1606</link><guid isPermaLink="true">https://forum.rexygen.com/post/1606</guid><dc:creator><![CDATA[Tourneur]]></dc:creator><pubDate>Tue, 18 Jun 2024 21:10:05 GMT</pubDate></item><item><title><![CDATA[Reply to Custom display component on Tue, 18 Jun 2024 06:42:35 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/1301">@Tourneur</a> Hi! For the gauge sketched at the beginning of this topic you don't need any hand coding and the old forum post is overkill.</p>
<p dir="auto">Just have a look at the example 0301-08 HMI Animation DEMO and read HMI documentation - Chapter 3.3.1 Group Animation: <a href="https://www.rexygen.com/doc/ENGLISH/MANUALS/RexHMI/RexHMI_ENG.html#x1-180003.3.1">https://www.rexygen.com/doc/ENGLISH/MANUALS/RexHMI/RexHMI_ENG.html#x1-180003.3.1</a></p>
]]></description><link>https://forum.rexygen.com/post/1603</link><guid isPermaLink="true">https://forum.rexygen.com/post/1603</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Tue, 18 Jun 2024 06:42:35 GMT</pubDate></item><item><title><![CDATA[Reply to Custom display component on Mon, 17 Jun 2024 20:38:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/5">@cechurat</a></p>
<p dir="auto">Hello, Cechurat,</p>
<p dir="auto">First of all, i send you my apologies for this very late reply.</p>
<p dir="auto">Before responding to you, I would like to understand how can I realize this component.</p>
<p dir="auto">First of all, I readed the script tutorial in this previous forum :<br />
<a href="https://www.rexcontrols.com/forum/viewtopic.php?pid=180#p180">https://www.rexcontrols.com/forum/viewtopic.php?pid=180#p180</a></p>
<p dir="auto">And try to start from the first exemple #4, in case to understood the principe of realisation.</p>
<p dir="auto">But, start one thing :</p>
<p dir="auto">This tutorial, start by :</p>
<p dir="auto">Open a blank document in inskape (Without "RexHmi Config object")</p>
<p dir="auto">Does i need to install a generic version of Inskape, a no Rex version ?</p>
<p dir="auto">Does it couldn't risk to detect the rex version, and froze if I install this generic version into my computer ?</p>
<p dir="auto">Second thing,</p>
<p dir="auto">At step 12, Mr Sobota, said, add the ns0:tag</p>
<p dir="auto">Ok, but how could do it ?</p>
<p dir="auto">I try to compare with issues found on forum, but with a certain clearly differences.</p>
<p dir="auto">Does it this tutorial I have to see step by step ?<br />
Or does I completly not in the correct way ?</p>
<p dir="auto">Thanks any help</p>
]]></description><link>https://forum.rexygen.com/post/1602</link><guid isPermaLink="true">https://forum.rexygen.com/post/1602</guid><dc:creator><![CDATA[Tourneur]]></dc:creator><pubDate>Mon, 17 Jun 2024 20:38:53 GMT</pubDate></item><item><title><![CDATA[Reply to Custom display component on Wed, 05 Jun 2024 06:00:41 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/1301">@Tourneur</a> Hi! Thanks for your question. Yes, this is possible using basic animations. The green line will rotate according to the desired signal.</p>
<p dir="auto">Have a look at the example: 0301-08 HMI Animation DEMO.</p>
]]></description><link>https://forum.rexygen.com/post/1587</link><guid isPermaLink="true">https://forum.rexygen.com/post/1587</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Wed, 05 Jun 2024 06:00:41 GMT</pubDate></item></channel></rss>
