<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[RPi internet issues with REXYGEN 3.0]]></title><description><![CDATA[<p dir="auto">Hi All,</p>
<p dir="auto">I've just got a RPi 5 and installed Book Worm (64bit) on to it. I then used REXYGEN studio to bootstrap the runtime etc. Once I had done this, the pi lost internet access. I tired a few things but everything looked ok. I reinstalled Book Worm onto the SD card and started again. This time I used the manual RPi install method.</p>
<p dir="auto">sudo wget <a href="https://download.rexcontrols.cz/partner/testing/rexygen.gpg">https://download.rexcontrols.cz/partner/testing/rexygen.gpg</a> -O /etc/apt/trusted.gpg.d/rexygen.gpg</p>
<p dir="auto">echo 'deb <a href="https://download.rexcontrols.cz/partner/testing/rexygen/debian/">https://download.rexcontrols.cz/partner/testing/rexygen/debian/</a> bookworm rexygen dwm' | <br />
sudo tee -a /etc/apt/sources.list.d/rexygen-testing.list</p>
<p dir="auto">sudo apt update<br />
sudo apt install rexygen-runtime</p>
<p dir="auto">This worked and internet access was ok, then I installed the dwm interface and it broke something in the internet settings.</p>
<p dir="auto">Does the dwm install change network settings that might cause the pi to loose internet access?</p>
]]></description><link>https://forum.rexygen.com/topic/586/rpi-internet-issues-with-rexygen-3-0</link><generator>RSS for Node</generator><lastBuildDate>Mon, 08 Jun 2026 14:46:52 GMT</lastBuildDate><atom:link href="https://forum.rexygen.com/topic/586.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 10 Jun 2024 01:55:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to RPi internet issues with REXYGEN 3.0 on Wed, 12 Jun 2024 22:45:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/186">@Jan-Reitinger</a> Hi Jan,</p>
<p dir="auto">All sorted, thank you.</p>
]]></description><link>https://forum.rexygen.com/post/1595</link><guid isPermaLink="true">https://forum.rexygen.com/post/1595</guid><dc:creator><![CDATA[MikeyH]]></dc:creator><pubDate>Wed, 12 Jun 2024 22:45:25 GMT</pubDate></item><item><title><![CDATA[Reply to RPi internet issues with REXYGEN 3.0 on Wed, 12 Jun 2024 11:04:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/11">@MikeyH</a> Hi Mike,<br />
the DWM installation should now behave correctly. For Bookworm, the systemd-resolved package, which did not exist in previous distributions, should now be installed with DWM. We are sorry for complications.</p>
]]></description><link>https://forum.rexygen.com/post/1594</link><guid isPermaLink="true">https://forum.rexygen.com/post/1594</guid><dc:creator><![CDATA[Jan Reitinger]]></dc:creator><pubDate>Wed, 12 Jun 2024 11:04:13 GMT</pubDate></item><item><title><![CDATA[Reply to RPi internet issues with REXYGEN 3.0 on Tue, 11 Jun 2024 19:50:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/186">@Jan-Reitinger</a> Hi Jan,</p>
<p dir="auto">Thanks for your help as always, much appreciated.</p>
]]></description><link>https://forum.rexygen.com/post/1593</link><guid isPermaLink="true">https://forum.rexygen.com/post/1593</guid><dc:creator><![CDATA[MikeyH]]></dc:creator><pubDate>Tue, 11 Jun 2024 19:50:17 GMT</pubDate></item><item><title><![CDATA[Reply to RPi internet issues with REXYGEN 3.0 on Tue, 11 Jun 2024 10:22:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/11">@MikeyH</a> Hi Mike,<br />
We found out that there were changes to systemd in Bookworm. On the clean image, there is a problem in DNS after installing DWM. We will adjust the DWM installation accordingly so that everything works on Bookworm and older distributions. We'll let you know when we have a solution.</p>
]]></description><link>https://forum.rexygen.com/post/1592</link><guid isPermaLink="true">https://forum.rexygen.com/post/1592</guid><dc:creator><![CDATA[Jan Reitinger]]></dc:creator><pubDate>Tue, 11 Jun 2024 10:22:19 GMT</pubDate></item><item><title><![CDATA[Reply to RPi internet issues with REXYGEN 3.0 on Mon, 10 Jun 2024 19:52:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/186">@Jan-Reitinger</a> Hi Jan,</p>
<p dir="auto">Thank you for the reply.</p>
<p dir="auto">I'm not using a static IP, just DHCP on my home router at the moment. I've seen the changes DWM does with static IP, but have never seen it cause issues with normal DHCP. I've only used the Monarco image for a while now and have never had problems. This only seem to be when I use the bear raspberry pi command to install DWM.</p>
]]></description><link>https://forum.rexygen.com/post/1590</link><guid isPermaLink="true">https://forum.rexygen.com/post/1590</guid><dc:creator><![CDATA[MikeyH]]></dc:creator><pubDate>Mon, 10 Jun 2024 19:52:37 GMT</pubDate></item><item><title><![CDATA[Reply to RPi internet issues with REXYGEN 3.0 on Mon, 10 Jun 2024 18:05:59 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/11">@MikeyH</a> Hi Mike,<br />
the DWM uses <a href="https://wiki.archlinux.org/title/systemd-networkd">systemd-networkd</a> for network management. The default configuration for ethernet is in the /etc/systemd/network/eth0.network file:</p>
<pre><code>[Match]
Name=eth0
[Network]
Address=169.254.0.100/16
DHCP=yes
<p dir="auto">that means that the DHCP client is allowed by default and there is the Windows fallback 169.254.0.100.</p>
<p dir="auto">This default settings can cause problems if you are using static IP.</p>
]]></description><link>https://forum.rexygen.com/post/1589</link><guid isPermaLink="true">https://forum.rexygen.com/post/1589</guid><dc:creator><![CDATA[Jan Reitinger]]></dc:creator><pubDate>Mon, 10 Jun 2024 18:05:59 GMT</pubDate></item></channel></rss>
