<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Rexcore-runtime not Running after installation]]></title><description><![CDATA[<p dir="auto">I did a fresh Installation for a RaspberryPi 2b with Debian Bookworm. The rexcore 3.0.3 is crashing with a Core Dump when staring the rexcore.service.</p>
<p dir="auto">gninaus@raspberrypi03:~ $ systemctl status rexcore.service<br />
× rexcore.service - REXYGEN Runtime Core (RexCore)<br />
Loaded: loaded (/lib/systemd/system/rexcore.service; enabled; preset: enabled)<br />
Active: failed (Result: core-dump) since Thu 2024-11-07 13:04:26 CET; 1h 57min ago<br />
Duration: 402ms<br />
Main PID: 4080 (code=dumped, signal=ILL)<br />
CPU: 147ms</p>
<p dir="auto">Nov 07 13:04:26 raspberrypi03 systemd[1]: Started rexcore.service - REXYGEN Runtime Core (RexCore).<br />
Nov 07 13:04:26 raspberrypi03 systemd[1]: rexcore.service: Main process exited, code=dumped, status=4/ILL<br />
Nov 07 13:04:26 raspberrypi03 systemd[1]: rexcore.service: Failed with result 'core-dump'.<br />
gninaus@raspberrypi03:~ $</p>
]]></description><link>https://forum.rexygen.com/topic/593/rexcore-runtime-not-running-after-installation</link><generator>RSS for Node</generator><lastBuildDate>Mon, 12 Oct 2026 19:01:32 GMT</lastBuildDate><atom:link href="https://forum.rexygen.com/topic/593.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 07 Nov 2024 14:02:16 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Rexcore-runtime not Running after installation on Wed, 27 Nov 2024 08:48:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/16">@gninaus</a> Hi Guenther,</p>
<p dir="auto">the fix is available in our daily build repository: <a href="https://download.rexcontrols.cz/partner/daily/">https://download.rexcontrols.cz/partner/daily/</a></p>
<p dir="auto">Feel free to test it and report back.</p>
]]></description><link>https://forum.rexygen.com/post/1640</link><guid isPermaLink="true">https://forum.rexygen.com/post/1640</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Wed, 27 Nov 2024 08:48:21 GMT</pubDate></item><item><title><![CDATA[Reply to Rexcore-runtime not Running after installation on Mon, 11 Nov 2024 08:05:43 GMT]]></title><description><![CDATA[<p dir="auto">Hi Guenther,</p>
<p dir="auto">Thank you for your bug report. Our developers fixed that immediately. The fix is now under test, and I will let you know once it is publicly available.</p>
<p dir="auto">Thank you for your understanding.</p>
]]></description><link>https://forum.rexygen.com/post/1639</link><guid isPermaLink="true">https://forum.rexygen.com/post/1639</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Mon, 11 Nov 2024 08:05:43 GMT</pubDate></item></channel></rss>
