<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Update REXcore etc on Monarco]]></title><description><![CDATA[<p dir="auto">Hi All,</p>
<p dir="auto">I have a Monarco running REXcore 3.0.1 and I'm now using the new 3.0.3 studio. It won't connect, error code-126, which I assume is a compatibility issue.</p>
<p dir="auto">Is there a way to update this without a complete reinstall?</p>
]]></description><link>https://forum.rexygen.com/topic/597/update-rexcore-etc-on-monarco</link><generator>RSS for Node</generator><lastBuildDate>Tue, 09 Jun 2026 17:43:45 GMT</lastBuildDate><atom:link href="https://forum.rexygen.com/topic/597.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 25 Feb 2025 21:03:51 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Update REXcore etc on Monarco on Wed, 26 Feb 2025 21:10:39 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/5">@cechurat</a> Hi Tomas,</p>
<p dir="auto">That worked thank you, I used apt-get which didn't seem to update the REX stuff.</p>
<p dir="auto">Thank you<br />
]]></description><link>https://forum.rexygen.com/post/1664</link><guid isPermaLink="true">https://forum.rexygen.com/post/1664</guid><dc:creator><![CDATA[MikeyH]]></dc:creator><pubDate>Wed, 26 Feb 2025 21:10:39 GMT</pubDate></item><item><title><![CDATA[Reply to Update REXcore etc on Monarco on Wed, 26 Feb 2025 11:13:26 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/11">@MikeyH</a> Hi Mike,</p>
<p dir="auto">Yes, your assumption is right. Always try to have the same versions both on your PC and on your target device.<br />
The update process depends on the state of your OS image. If you don't need any fixed version of other packages for some reason, I would perform an  upgrade of the whole OS:</p>
<pre><code>sudo apt update
sudo apt upgrade
<p dir="auto">If it won't help, you will probably need to change the location of the REXYGEN packages - for more details, see Chapter "Manual installation" in the documentation provided with the 3.0.3 Development tools.</p>
<p dir="auto">Let me know if it helps.</p>
]]></description><link>https://forum.rexygen.com/post/1662</link><guid isPermaLink="true">https://forum.rexygen.com/post/1662</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Wed, 26 Feb 2025 11:13:26 GMT</pubDate></item></channel></rss>
