<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[HMI Designer 3.2.5]]></title><description><![CDATA[<p dir="auto">Hi All,</p>
<p dir="auto">Any reason HMI Designer 3.2.5 (c049b2ff4e, 2023-02-13, custom) does not have the REXYGEN HMI extension when installed?<br />
<img src="/assets/uploads/files/1740604424845-d03a6c3c-a22d-4da1-a27b-54e38646e252-image.png" alt="d03a6c3c-a22d-4da1-a27b-54e38646e252-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Have I downloaded the wrong program?</p>
]]></description><link>https://forum.rexygen.com/topic/599/hmi-designer-3-2-5</link><generator>RSS for Node</generator><lastBuildDate>Mon, 09 Nov 2026 17:13:14 GMT</lastBuildDate><atom:link href="https://forum.rexygen.com/topic/599.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 26 Feb 2025 21:14:23 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to HMI Designer 3.2.5 on Thu, 05 Nov 2026 17:09:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/5">@cechurat</a> Hi Tomas,</p>
<p dir="auto">Should HMI designer be opened from the tray monitor or via the HMI design program it self?</p>
<p dir="auto">I still can't see the REXYGEN extension, or does this version work differently?<br />
<img src="/assets/uploads/files/1793898537524-ab4e203c-a84e-4f54-92ca-93033271055b-image.png" alt="ab4e203c-a84e-4f54-92ca-93033271055b-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.rexygen.com/post/1767</link><guid isPermaLink="true">https://forum.rexygen.com/post/1767</guid><dc:creator><![CDATA[MikeyH]]></dc:creator><pubDate>Thu, 05 Nov 2026 17:09:09 GMT</pubDate></item><item><title><![CDATA[Reply to HMI Designer 3.2.5 on Thu, 05 Nov 2026 06:52:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/11">@MikeyH</a> Hi Mike,</p>
<p dir="auto">Sorry, I forgot to mention one important thing: In your current REXYGEN installation, open the file C:\Program Files\REX Controls\REXYGEN 3.0.X.YYYYY\HmiDesigner\version.req and change its contents to 3.4.</p>
<p dir="auto">The new HMI Designer requires REXYGEN v3 (I recommend using the latest available 3.0.5)</p>
<p dir="auto">Then the Studio should automatically use the new HMI Designer. You can check it in the compile log after you compile any project with HMI.</p>
<p dir="auto">Let me know if it helped.</p>
<p dir="auto">Tomas</p>
]]></description><link>https://forum.rexygen.com/post/1766</link><guid isPermaLink="true">https://forum.rexygen.com/post/1766</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Thu, 05 Nov 2026 06:52:05 GMT</pubDate></item><item><title><![CDATA[Reply to HMI Designer 3.2.5 on Wed, 04 Nov 2026 22:08:22 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/5">@cechurat</a> Hi Tomas,</p>
<p dir="auto">I have it downloaded, how do I use this version? I can't see any extensions like previous versions or any way to link it to REX</p>
]]></description><link>https://forum.rexygen.com/post/1765</link><guid isPermaLink="true">https://forum.rexygen.com/post/1765</guid><dc:creator><![CDATA[MikeyH]]></dc:creator><pubDate>Wed, 04 Nov 2026 22:08:22 GMT</pubDate></item><item><title><![CDATA[Reply to HMI Designer 3.2.5 on Tue, 03 Nov 2026 08:01:23 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/11">@MikeyH</a> Hi Mike,</p>
<p dir="auto">I'm not sure about this specific issue but we have already moved forward with native Inkscape integration of REXYGEN component.</p>
<p dir="auto">Can you try out REXYGEN HMI Designer version 3.4.5? You can get it here: <a href="https://download.rexcontrols.cz/partner/daily/rexygen/hmidesigner/signed/">https://download.rexcontrols.cz/partner/daily/rexygen/hmidesigner/signed/</a></p>
]]></description><link>https://forum.rexygen.com/post/1764</link><guid isPermaLink="true">https://forum.rexygen.com/post/1764</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Tue, 03 Nov 2026 08:01:23 GMT</pubDate></item><item><title><![CDATA[Reply to HMI Designer 3.2.5 on Mon, 02 Nov 2026 22:39:28 GMT]]></title><description><![CDATA[<p dir="auto">Hi Tomas,</p>
<p dir="auto">Sorry fo rthe huge delay in this! Things happned.</p>
<p dir="auto">Do you know why this was happening in the end?</p>
]]></description><link>https://forum.rexygen.com/post/1762</link><guid isPermaLink="true">https://forum.rexygen.com/post/1762</guid><dc:creator><![CDATA[MikeyH]]></dc:creator><pubDate>Mon, 02 Nov 2026 22:39:28 GMT</pubDate></item><item><title><![CDATA[Reply to HMI Designer 3.2.5 on Sun, 30 Mar 2025 21:32:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/5">@cechurat</a> Hi Tomas,</p>
<p dir="auto">I will try and record this this week, sorry for the delay.</p>
]]></description><link>https://forum.rexygen.com/post/1678</link><guid isPermaLink="true">https://forum.rexygen.com/post/1678</guid><dc:creator><![CDATA[MikeyH]]></dc:creator><pubDate>Sun, 30 Mar 2025 21:32:19 GMT</pubDate></item><item><title><![CDATA[Reply to HMI Designer 3.2.5 on Tue, 04 Mar 2025 11:19:33 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/11">@MikeyH</a> Hi Mike,</p>
<p dir="auto">Thanks for reporting this. This is really weird. Please, can you record and share your screen? E.g. using online tool <a href="https://gifcap.dev/">https://gifcap.dev/</a></p>
]]></description><link>https://forum.rexygen.com/post/1675</link><guid isPermaLink="true">https://forum.rexygen.com/post/1675</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Tue, 04 Mar 2025 11:19:33 GMT</pubDate></item><item><title><![CDATA[Reply to HMI Designer 3.2.5 on Mon, 03 Mar 2025 18:15:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/5">@cechurat</a> Hi Tomas,</p>
<p dir="auto">My versions are below.<br />
<img src="/assets/uploads/files/1741025472394-36eb2e35-47d4-4518-b398-af75e6271a8f-image.png" alt="36eb2e35-47d4-4518-b398-af75e6271a8f-image.png" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1741025511530-0e48016d-a583-4dec-8fd8-13261ecffa86-image.png" alt="0e48016d-a583-4dec-8fd8-13261ecffa86-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">The parse error has gone now. What seems to happen now is after I set the connect strings in the HMI configuration, it doesn't save them so are always blank when I open it again.<br />
<img src="/assets/uploads/files/1741025609555-48f5394f-696e-4ca0-af30-f8a48d8f2a86-image.png" alt="48f5394f-696e-4ca0-af30-f8a48d8f2a86-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Thanks for your help with this</p>
]]></description><link>https://forum.rexygen.com/post/1674</link><guid isPermaLink="true">https://forum.rexygen.com/post/1674</guid><dc:creator><![CDATA[MikeyH]]></dc:creator><pubDate>Mon, 03 Mar 2025 18:15:15 GMT</pubDate></item><item><title><![CDATA[Reply to HMI Designer 3.2.5 on Mon, 03 Mar 2025 09:09:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/11">@MikeyH</a> Hi Mike!</p>
<p dir="auto">Do you use the same versions of Development tools and REXYGEN Runtime?<br />
<img src="/assets/uploads/files/1740992952732-beac153b-556a-46bc-86c1-b18189593ac1-image.png" alt="beac153b-556a-46bc-86c1-b18189593ac1-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">The TRND not providing any data seems to be disabled - is it active in the running project?</p>
<p dir="auto">The error message about parsing the output can be omitted - the extension returns something which throws this error. It won't affect the behaviour of the HMI. We will try to fix it. Can you share your source files with us?</p>
]]></description><link>https://forum.rexygen.com/post/1673</link><guid isPermaLink="true">https://forum.rexygen.com/post/1673</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Mon, 03 Mar 2025 09:09:31 GMT</pubDate></item><item><title><![CDATA[Reply to HMI Designer 3.2.5 on Mon, 03 Mar 2025 00:35:45 GMT]]></title><description><![CDATA[<p dir="auto">I'm also getting this for the logger too, but can't work out why, any ideas?<br />
<img src="/assets/uploads/files/1740962078631-ae607827-9db1-482e-8892-50f5ac511aa7-image.png" alt="ae607827-9db1-482e-8892-50f5ac511aa7-image.png" class=" img-fluid img-markdown" /><br />
<img src="/assets/uploads/files/1740962139996-75d8e6f6-aa7c-4e40-b3b0-070c1bf6fb64-image.png" alt="75d8e6f6-aa7c-4e40-b3b0-070c1bf6fb64-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.rexygen.com/post/1672</link><guid isPermaLink="true">https://forum.rexygen.com/post/1672</guid><dc:creator><![CDATA[MikeyH]]></dc:creator><pubDate>Mon, 03 Mar 2025 00:35:45 GMT</pubDate></item><item><title><![CDATA[Reply to HMI Designer 3.2.5 on Sun, 02 Mar 2025 22:08:51 GMT]]></title><description><![CDATA[<p dir="auto">ok I've got it exported, now. I just synced the project compile with the HMI designer open and it worked. But now the TRND graph doesn't show the data. If does briefly when changing the time line.<br />
<img src="/assets/uploads/files/1740953077997-70171cbd-0fe7-4d4a-b8f1-aff3d4487298-image.png" alt="70171cbd-0fe7-4d4a-b8f1-aff3d4487298-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">It works if I give the Y axis a min/max range, but i though it would auto adjust?</p>
]]></description><link>https://forum.rexygen.com/post/1671</link><guid isPermaLink="true">https://forum.rexygen.com/post/1671</guid><dc:creator><![CDATA[MikeyH]]></dc:creator><pubDate>Sun, 02 Mar 2025 22:08:51 GMT</pubDate></item><item><title><![CDATA[Reply to HMI Designer 3.2.5 on Sun, 02 Mar 2025 21:49:17 GMT]]></title><description><![CDATA[<p dir="auto">I can connect and select the path etc<br />
<img src="/assets/uploads/files/1740951033530-97976d73-c8bf-4347-90e7-2ef34f303848-image.png" alt="97976d73-c8bf-4347-90e7-2ef34f303848-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I then get the parsed error</p>
<p dir="auto">It's a bit different than I remember and I can't seem to export the HMI svg etc, has that changed?</p>
]]></description><link>https://forum.rexygen.com/post/1670</link><guid isPermaLink="true">https://forum.rexygen.com/post/1670</guid><dc:creator><![CDATA[MikeyH]]></dc:creator><pubDate>Sun, 02 Mar 2025 21:49:17 GMT</pubDate></item><item><title><![CDATA[Reply to HMI Designer 3.2.5 on Sun, 02 Mar 2025 20:21:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/5">@cechurat</a> Hi Tomas,</p>
<p dir="auto">That makes sense and worked perfectly, getting this error now. What have I done to get this?<br />
<img src="/assets/uploads/files/1740946860492-ade37353-bae3-4b32-a12e-8299ba77848d-image.png" alt="ade37353-bae3-4b32-a12e-8299ba77848d-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.rexygen.com/post/1669</link><guid isPermaLink="true">https://forum.rexygen.com/post/1669</guid><dc:creator><![CDATA[MikeyH]]></dc:creator><pubDate>Sun, 02 Mar 2025 20:21:25 GMT</pubDate></item><item><title><![CDATA[Reply to HMI Designer 3.2.5 on Thu, 27 Feb 2025 13:20:18 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/11">@MikeyH</a> Hi Mike,</p>
<p dir="auto">The version you have is correct. The issue is in running the HMI Designer without proper initialization. Try to run the Designer via REXYGEN TrayMon (see the screenshot)</p>
<p dir="auto"><img src="/assets/uploads/files/1740662383989-408ba4f0-1e2c-4002-a715-123c50da9987-image.png" alt="408ba4f0-1e2c-4002-a715-123c50da9987-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">The thing is that you need to tell the Designer which REXYGEN version is valid. The reason for this is that one Designer version is shared among all REXYGEN versions, so you don't have to install all Designer things every time you install a new REXYGEN version. If you run Designer without this connection, it won't work. Running the Designer via TrayMon should solve this.</p>
]]></description><link>https://forum.rexygen.com/post/1666</link><guid isPermaLink="true">https://forum.rexygen.com/post/1666</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Thu, 27 Feb 2025 13:20:18 GMT</pubDate></item></channel></rss>
