<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Complier issue]]></title><description><![CDATA[<p dir="auto"><img src="/assets/uploads/files/1749159705594-512aa70e-c58f-4105-9720-573a88dba043-image-resized.png" alt="512aa70e-c58f-4105-9720-573a88dba043-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I am not sure how to make the stop in the lower right hand corner run</p>
]]></description><link>https://forum.rexygen.com/topic/605/complier-issue</link><generator>RSS for Node</generator><lastBuildDate>Mon, 10 Aug 2026 23:47:39 GMT</lastBuildDate><atom:link href="https://forum.rexygen.com/topic/605.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 05 Jun 2025 22:12:49 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Complier issue on Tue, 10 Jun 2025 08:34:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/5722">@har</a> Hi har,</p>
<p dir="auto">Thanks for the additional info. We are not able to provide free support on this since it's your custom Python script. The error is not related to the Rexygen ecosystem. It seems that the CPU dispatcher is being initialised multiple times.</p>
<p dir="auto">Tomas</p>
]]></description><link>https://forum.rexygen.com/post/1697</link><guid isPermaLink="true">https://forum.rexygen.com/post/1697</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Tue, 10 Jun 2025 08:34:30 GMT</pubDate></item><item><title><![CDATA[Reply to Complier issue on Mon, 09 Jun 2025 16:58:01 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/5">@cechurat</a> Hi Thomas when I hover my mouse over the error I get this message.<br />
<img src="/assets/uploads/files/1749488257310-08cc5ce2-fdfa-4392-8cef-9842f6116a59-image.png" alt="08cc5ce2-fdfa-4392-8cef-9842f6116a59-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I am not quite sure what it means or how to fix it</p>
]]></description><link>https://forum.rexygen.com/post/1695</link><guid isPermaLink="true">https://forum.rexygen.com/post/1695</guid><dc:creator><![CDATA[har]]></dc:creator><pubDate>Mon, 09 Jun 2025 16:58:01 GMT</pubDate></item><item><title><![CDATA[Reply to Complier issue on Fri, 06 Jun 2025 20:01:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/5722">@har</a> Yes, the issue is in initialisation of the Python Block. If you wait a second with the mouse on the message <img src="/assets/uploads/files/1749239959965-377b94ec-fd02-467a-985c-a0611d9455ba-image-resized.png" alt="377b94ec-fd02-467a-985c-a0611d9455ba-image.png" class=" img-fluid img-markdown" /><br />
it will show you more instead of "..." which might help you to find the issue easier.</p>
]]></description><link>https://forum.rexygen.com/post/1694</link><guid isPermaLink="true">https://forum.rexygen.com/post/1694</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Fri, 06 Jun 2025 20:01:02 GMT</pubDate></item><item><title><![CDATA[Reply to Complier issue on Fri, 06 Jun 2025 17:13:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/5">@cechurat</a> <img src="/assets/uploads/files/1749229894340-0244efc4-6f33-4996-80e4-355312bae54c-image-resized.png" alt="0244efc4-6f33-4996-80e4-355312bae54c-image.png" class=" img-fluid img-markdown" /><br />
I think the problem might be in the python block.</p>
<p dir="auto">import numpy as np<br />
import time<br />
from numpy import sin,cos,pi<br />
from scipy.integrate import solve_ivp, solve_bvp, quad, odeint<br />
from scipy.linalg import solve_continuous_are<br />
from scipy.interpolate import interp1d<br />
#import matplotlib.pyplot as plt<br />
from PyRexExt import REX</p>
<p dir="auto">def init():<br />
global ω,ζ,π,τ,τ1,τpred,xmax,umax,θinti,θdotinit,xinit,xdotinit,xstate_init,θend1,θend2,θdotend,xend,xdotend,xstate_end1,xstate_end2,Q,R,ts,dt,ts1,bvpfcn,bcfcn,ff,uff0,uff,runningCost,A,B,mRiccati,Sall,Ball,Kall,fpred,us,j<br />
global xstate_end,FFsol,X,uff,vs,Kvec,Xlast,Klast</p>
<pre><code>############################################ Define parameters
ω          = REX.u1.v
ζ          = REX.u2.v;                      # pendulum friction (scaled: 1 = critical damping)
π          = pi;                            # π = 3.14159...
τ          = 2*π                            # swingup time = 1 period, in scaled units
τpred      = 1                              # allow for calculation time, in scaled units
τ1         = 2*τ                            # for sim: swingup + balance time
xmax       = 2;                             # track limits at ±xmax
umax       = 5;                             # clip u for simulation test ONLY (not design)
θinit      = 0;                             # initial angle of pendulum
θdotinit   = 0.0;                           # initial angular velocity of pendulum
xinit      = 0.0;                           # initial position of cart
xdotinit   = 0.0;                           # initial velocity of cart
xstate_init = np.array([θinit,θdotinit,xinit,xdotinit])        # eventually, from expt.
θend1      = π                              # CCW swingup,   assume θinit ∊ (-π,π)
θend2      = -π                             # CW swingup
θdotend    = 0.0;                           # final angular velocity of pendulum
xend       = 0.0 * xmax;                    # final cart position
xdotend    = 0.0;                           # final cart velocity
xstate_end1 = np.array([θend1,θdotend,xend,xdotend])   # modify for swing down, transport, ...
xstate_end2 = np.array([θend2,θdotend,xend,xdotend])   # modify for swing down, transport, ...
Q    = np.diag([1,10,1,1])                  # weighting for states for LQR
R    = np.array([10])                       # weighting for input for LQR
ts   = np.arange(0, τ, 0.01*ω)       # swing up in τ
dt   = 0.01*ω
ts1  = np.arange(0, τ1, 0.01*ω)      # swing up in τ, balance for another τ
############################################# Define functions
def bvpfcn(t, X):                           # solve coupled state-adjoint system
    θ, θdot, x, xdot, λθ, λθdot, λx, λxdot = X
    dX = np.zeros((8, X.shape[1]))          # array dimension is 8 * nx
    sinθ = sin(θ);  cosθ = cos(θ)
    u = -λxdot + λθdot*cosθ
    dX[0] = θdot
    dX[1] = -sinθ - u*cosθ
    dX[2] = xdot
    dX[3] = u
    dX[4] = λθdot * (cosθ - u*sinθ)
    dX[5] = - λθ
    # dX[6] = -x**3 / xmax**4                 # or:  from running cost term (x/xmax)**4
    dX[6] = 0                               # running cost independent of x
    dX[7] = -λx
    return dX                               # Return derivatives (array)
def bcfcn(x0, xτ):                          # boundary conditions for 4d-state at t = 0, τ
    dx0 = x0[0:4] - xstate_init             # boundary condition for 4d state at t=0
    dxτ = xτ[0:4] - xstate_end              # bc                              at t=τ
    return np.hstack((dx0,dxτ))             # 8-dim vector for solve_bvp
def ff(x0,xτ,τ):                            # ff state x0 → xτ in τ
    θinit,_,xinit,_ = x0
    θend, _,xend, _ = xτ
    nt = 21                                            # number of time points, to start
    tvec = np.linspace(0, τ, nt)
    xλguess = np.zeros((8, nt))                        # initial guesses for state trajectories
    xλguess[0, :] = np.linspace(θinit, θend, num=nt)   # θ linear, θinit → θend
    xλguess[2, :] = np.linspace(xinit, xend, num=nt)   # x linear, xinit → xend
    FFsol = solve_bvp(bvpfcn, bcfcn, tvec, xλguess, tol=0.1)   # solve boundary-value problem
    return FFsol.sol
def uff0(t):                                # feedforward acceleration (cannot evaluate on arrays)
    θ,_,_,_,_,λθdot,_,λxdot = FFsol(t)      # evaluate interp funcs at time=t
    uff0 = -λxdot + λθdot*cos(θ) if t&lt;τ else 0
    return uff0
uff = np.vectorize(uff0)                    # define vectorized version (can call with array)
def runningCost(t):                         # to calc cost of the feedforward command
    return 0.5*uff0(t)**2
def A(t):                                   # dynamical matrix (local linear, nominal)
    θ         = FFsol(t)[0]                 # FFsol from FF function
    Amat      = np.zeros((4,4))             # 4 is from xstate.shape[0]
    Amat[0,1] = 1
    Amat[1,0] = -cos(θ) + uff(t)*sin(θ)
    Amat[1,1] = 0
    Amat[2,3] = 1
    return Amat                             # evaluated at time t
def B(t):                                   # input vector (local linear, nominal)
    Bmat    = np.zeros((4,1))               # 4 is from xstate.shape[0]
    Bmat[1] = -cos(θ)
    Bmat[3] = 1
    return Bmat
def mRiccati(t,S):                          # derivatives for matrix Riccati (vector form)
    Smat = S.reshape((4,4))                 # convert 16 vector to 4x4 matrix
    A0 = A(t)                               # current dynamical matrix
    B0 = B(t)                               # current input vector
    dSmat = - A0.T @ Smat - Smat @ A0 - Q + Smat @ (B0 @ B0.T) @ Smat / R[0]
    dS = dSmat.reshape((16))                # convert 4x4 matrix to 16 vector
    return dS
def Sall(Send,τ,tvec):                      # S matrix evaluated at times tvec
    Send1 = Send.reshape((16))
    t_span = (τ, 0)                         # solve backwards in time, from τ → 0
    Ssol1 = solve_ivp(mRiccati, t_span, Send1, dense_output=True).sol
    return Ssol1(tvec).reshape(4,4,tvec.size)   # evaluate on tvec
def Ball(FFsol,tvec):                       # input matrix (local linear, nominal)
    θ       = FFsol(tvec)[0]
    nt      = tvec.size
    Bmat    = np.zeros((4,nt))              # 4 is from xstate.shape[0]
    Bmat[1] = -cos(θ)
    Bmat[3] = np.ones((nt))
    return Bmat
def Kall(Send,FFsol,τ,tvec):                # for graphing
    tvec1 = np.clip(tvec, 0, τ)             # elements beyond ff range are clipped to limits
    S = Sall(Send,τ,tvec1)                  # 4 x 4 x nt matrix (nt copies of 4x4 matrix
    B = Ball(FFsol,tvec1)                   # 4 x nt matrix     (nt copies of 4-vector)
    return np.einsum('ijk,jk-&gt;ik', S, B)/R[0]   # sum over inner index, element-mult tvec index
def fpred(t,xstate):                        # dynamical eqs, for constant-v input
    θ, θdot, _, xdot = xstate               # dynamical states
    dX = np.zeros((4))                      # 4 is from xstate.shape[0]
    dX[0] = θdot
    dX[1] = -sin(θ) - 2*ζ*θdot              # sim has pendulum friction, even if ff does not
    dX[2] = xdot
    dX[3] = 0                               # driving term is vtot; utot is a derived variable
    return dX
############################################# prediction of future state
xpred  = solve_ivp(fpred, (0, τpred), xstate_init, dense_output=True).sol # predict future state
xstate_init  = xpred(τpred)                 # "initial" state, as predicted τpred in future
θ0 = xstate_init[0];                        # extrapolated θ0 might not be ∊ (-π,π)
θ1 = (θ0+π) % (2*π) - π                     # modulus 2π
xstate_init[0] = θ1                         # new angle is ∊ (-π,π)
############################################# FF calculations
xstate_end = xstate_end1; θend = θend1
FFsol  = ff(xstate_init,xstate_end,τ)       # ff solution for 4-state and 4-adjoint, 0→τ
FFsol1 = FFsol
Jff1   = 0.5*np.sum(uff(ts)**2)*dt          # integrated running cost = overall cost
xstate_end = xstate_end2; θend = θend2
FFsol2 = FFsol
Jff2   = 0.5*np.sum(uff(ts)**2)*dt          # integrated running cost = overall cost
REX.y11.v = f"feedforward cost: θend = π, Jff1 = {Jff1:0.2f}, θend = -π, Jff2 = {Jff2:0.2f}"
if (Jff1 &lt; Jff2):
    FFsol = FFsol1;   xstate_end = xstate_end1
else:
    FFsol = FFsol2;   xstate_end = xstate_end2
############################################### fb calculations
Aend = A(τ)                                   # linear dynamics A matrix at t=τ
Bend = B(τ)                                   # linear input-coupling B vector at t=τ
Send = solve_continuous_are(Aend,Bend,Q,R)    # static S matrix from ARE
Kvec = Kall(Send,FFsol,τ,ts1)                 # feedback gain vectors for t in ts1
############################################### get arrays
θs,θdot,x, xdot,_,_,_,_ = FFsol(ts)
X = np.array([θs,θdot,x,xdot])
θlast,θdotlast,xlast,xdotlast,_,_,_,_=FFsol(2*π)                # Evaluate last values
Xlast   = np.array(&lsqb;&lsqb;θlast],[θdotlast],[xlast],[xdotlast&rsqb;&rsqb;)
X       = np.hstack((X,Xlast))                                  # add last value
Klast   = Kall(Send,FFsol,τ,2*π+0.1)
Kvec    = np.hstack((Kvec,Klast))
vs      = np.hstack((xdot,0))
j=0
<p dir="auto">def main():<br />
start_test = time.perf_counter()<br />
global j,X,uff,vs,Kvec</p>
<pre><code>if not REX.u0.v and j == 0:
    return
else: REX.y15.v = True
REX.y10.v= f"len(X)={len(X[0])}"
if (j &gt;= len(X[0])):
    REX.y8.v = 0
    return
# Value for every time
REX.y0.v = X[0][j]
REX.y1.v = X[1][j]
REX.y2.v = X[2][j]
REX.y3.v = X[3][j]
REX.y4.v = Kvec[0][j]
REX.y5.v = Kvec[1][j]
REX.y6.v = Kvec[2][j]
REX.y7.v = Kvec[3][j]
REX.y8.v = vs[j]
j += 1
test_time = time.perf_counter() - start_test
REX.y9.v = f"test time = {test_time:0.3f} s"
return
<p dir="auto">def exit():<br />
# PUT YOUR CODE HERE<br />
return</p>
]]></description><link>https://forum.rexygen.com/post/1693</link><guid isPermaLink="true">https://forum.rexygen.com/post/1693</guid><dc:creator><![CDATA[har]]></dc:creator><pubDate>Fri, 06 Jun 2025 17:13:42 GMT</pubDate></item><item><title><![CDATA[Reply to Complier issue on Fri, 06 Jun 2025 07:26:02 GMT]]></title><description><![CDATA[<p dir="auto">Hi har,</p>
<p dir="auto">thanks for your question. Please, can you share System Log? There should be some error which is preventing RexCore from running.</p>
]]></description><link>https://forum.rexygen.com/post/1692</link><guid isPermaLink="true">https://forum.rexygen.com/post/1692</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Fri, 06 Jun 2025 07:26:02 GMT</pubDate></item></channel></rss>
