<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Core Error &quot;Configuration requires higher license than available on the target device&quot;]]></title><description><![CDATA[<p dir="auto">I got an Core Error "Configuration requires higher license than available on the target device"<br />
Rex is running at the latest 3.0.5 Version, at the project were no changes since migrating from 2.50.<br />
Also the project seams to run well.</p>
]]></description><link>https://forum.rexygen.com/topic/616/core-error-configuration-requires-higher-license-than-available-on-the-target-device</link><generator>RSS for Node</generator><lastBuildDate>Sat, 14 Nov 2026 08:40:25 GMT</lastBuildDate><atom:link href="https://forum.rexygen.com/topic/616.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 10 Nov 2025 19:55:11 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Core Error &quot;Configuration requires higher license than available on the target device&quot; on Thu, 13 Nov 2025 08:44:04 GMT]]></title><description><![CDATA[<p dir="auto">In this specific case, the error message "Configuration requires higher license than available on the target device"﻿ indicates that RexCore did not find the new version of the license. If an older license version is present on the device and is sufficient concerning the scope of the project, this information should appear in the log and the project should run normally. In such a case, please ignore the error message.</p>
<p dir="auto">This error message will be revised in future versions of REXYGEN.</p>
]]></description><link>https://forum.rexygen.com/post/1727</link><guid isPermaLink="true">https://forum.rexygen.com/post/1727</guid><dc:creator><![CDATA[Jan Reitinger]]></dc:creator><pubDate>Thu, 13 Nov 2025 08:44:04 GMT</pubDate></item><item><title><![CDATA[Reply to Core Error &quot;Configuration requires higher license than available on the target device&quot; on Tue, 11 Nov 2025 11:15:01 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="https://forum.rexygen.com/uid/16">@gninaus</a>,</p>
<p dir="auto">With version 3.0, REXYGEN introduced a new licensing policy. You can find the details here:<br />
<a href="https://eshop.rexcontrols.com/pages/licensing-policy">https://eshop.rexcontrols.com/pages/licensing-policy</a></p>
<p dir="auto">Could you please send us your license information at <a href="mailto:support@rexygen.com">support@rexygen.com</a>?<br />
You can find the license info via REXYGEN Studio by using the menu Target -&gt; Connect and then again Target -&gt; Licensing.</p>
<p dir="auto">Also, please attach the REXYGEN Studio Compiler output related to licensing. Here’s an example:<br />
<img src="/assets/uploads/files/1762859656886-a7569447-a9d3-42b7-8544-5ebedf7652cf-image.png" alt="a7569447-a9d3-42b7-8544-5ebedf7652cf-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">This will help us identify what part of the configuration requires a higher license and provide further guidance.</p>
]]></description><link>https://forum.rexygen.com/post/1725</link><guid isPermaLink="true">https://forum.rexygen.com/post/1725</guid><dc:creator><![CDATA[Jan Reitinger]]></dc:creator><pubDate>Tue, 11 Nov 2025 11:15:01 GMT</pubDate></item></channel></rss>
