<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[HMI and Subsystem Mask]]></title><description><![CDATA[<p dir="auto">Hi All,</p>
<p dir="auto">If I have a CNR block in a subsystem, that I am using in a subsystem mask to give say a set point value. Can you still write a value to that CNR block via the HMI?</p>
]]></description><link>https://forum.rexygen.com/topic/64/hmi-and-subsystem-mask</link><generator>RSS for Node</generator><lastBuildDate>Sun, 18 Oct 2026 02:50:17 GMT</lastBuildDate><atom:link href="https://forum.rexygen.com/topic/64.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 30 Sep 2019 20:32:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to HMI and Subsystem Mask on Thu, 03 Oct 2019 03:47:52 GMT]]></title><description><![CDATA[<p dir="auto">Hi Jaroslav,</p>
<p dir="auto">Thank you for the help. I will give that a go and let you know what happens.</p>
]]></description><link>https://forum.rexygen.com/post/196</link><guid isPermaLink="true">https://forum.rexygen.com/post/196</guid><dc:creator><![CDATA[MikeyH]]></dc:creator><pubDate>Thu, 03 Oct 2019 03:47:52 GMT</pubDate></item><item><title><![CDATA[Reply to HMI and Subsystem Mask on Wed, 02 Oct 2019 17:11:49 GMT]]></title><description><![CDATA[<p dir="auto">Hi Mike,<br />
in such a case you should write the value from HMI to the subsystem mask, from where it will propagate to the corresponding CNR block. The connection string will be</p>
<pre><code>yourtask.subsystem:parameter
<p dir="auto">Hope this helps, let me know.</p>
]]></description><link>https://forum.rexygen.com/post/195</link><guid isPermaLink="true">https://forum.rexygen.com/post/195</guid><dc:creator><![CDATA[jaroslav_sobota]]></dc:creator><pubDate>Wed, 02 Oct 2019 17:11:49 GMT</pubDate></item></channel></rss>
