<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Zigbee, z-wave, Mqtt?]]></title><description><![CDATA[<p dir="auto">Hello, Can you explain to me if it is possible to recover information from the sensor "Mi aqara humidity" which works in mqtt? How should I do it ? what do I need? I see that it is possible to use it on domoticz or other ... it would be nice to add zwave, zigbee all possible gateways ... thank you in advance</p>
]]></description><link>https://forum.rexygen.com/topic/65/zigbee-z-wave-mqtt</link><generator>RSS for Node</generator><lastBuildDate>Sat, 18 Apr 2026 19:40:59 GMT</lastBuildDate><atom:link href="https://forum.rexygen.com/topic/65.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 03 Oct 2019 13:19:37 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Zigbee, z-wave, Mqtt? on Mon, 07 Oct 2019 07:44:31 GMT]]></title><description><![CDATA[<p dir="auto">ok thanks for the answer, i will try.</p>
]]></description><link>https://forum.rexygen.com/post/201</link><guid isPermaLink="true">https://forum.rexygen.com/post/201</guid><dc:creator><![CDATA[Geocipo]]></dc:creator><pubDate>Mon, 07 Oct 2019 07:44:31 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee, z-wave, Mqtt? on Mon, 07 Oct 2019 07:02:34 GMT]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">it is definitely possible to have the MQTT server on the same Raspberry with REXYGEN. It depends on the expected data load. Just have a look at Raspberry performance and CPU loads.</p>
]]></description><link>https://forum.rexygen.com/post/200</link><guid isPermaLink="true">https://forum.rexygen.com/post/200</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Mon, 07 Oct 2019 07:02:34 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee, z-wave, Mqtt? on Fri, 04 Oct 2019 15:19:30 GMT]]></title><description><![CDATA[<p dir="auto">hello Jaroslav, that's exactly what I wanted to know! thank you. Is it better to put the mqtt server on the raspberry with rexygen or put a new raspberry in parallel?</p>
]]></description><link>https://forum.rexygen.com/post/199</link><guid isPermaLink="true">https://forum.rexygen.com/post/199</guid><dc:creator><![CDATA[Geocipo]]></dc:creator><pubDate>Fri, 04 Oct 2019 15:19:30 GMT</pubDate></item><item><title><![CDATA[Reply to Zigbee, z-wave, Mqtt? on Fri, 04 Oct 2019 09:15:39 GMT]]></title><description><![CDATA[<p dir="auto">Hi,<br />
if you have the Aqara sensor correctly publishing data to MQTT broker, you can use the <a href="https://www.rexygen.com/doc/ENGLISH/MANUALS/BRef/MqttSubscribe.html">MqttSubscribe function block in REXYGEN</a> to subscribe to the corresponding topic.</p>
<p dir="auto">See example project 0407-01 which is included in REXYGEN Studio since version 2.50.8.</p>
<p dir="auto">Just for the record, here are some links to make the sensor work with MQTT broker (no guarantee and not sure if you need it):<br />
<a href="https://lemariva.com/blog/2019/04/zigbee-xiaomi-sensors-using-raspberry-pi-without-gateway">https://lemariva.com/blog/2019/04/zigbee-xiaomi-sensors-using-raspberry-pi-without-gateway</a><br />
<a href="https://www.reddit.com/r/homeassistant/comments/am0dg5/help_with_getting_rid_of_xiaomiaqara_gateways_and/">https://www.reddit.com/r/homeassistant/comments/am0dg5/help_with_getting_rid_of_xiaomiaqara_gateways_and/</a></p>
]]></description><link>https://forum.rexygen.com/post/198</link><guid isPermaLink="true">https://forum.rexygen.com/post/198</guid><dc:creator><![CDATA[jaroslav_sobota]]></dc:creator><pubDate>Fri, 04 Oct 2019 09:15:39 GMT</pubDate></item></channel></rss>
