<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Database value as parameter]]></title><description><![CDATA[<p dir="auto">Hi guys,</p>
<p dir="auto">Can any of you tell me if it is possible to use a database value as the value of TIMER_ pt? it sort of works with "refresh_from" in WebBuDi" but i still need to push enter to actually have it using it as the value of the TIMER_ pt. Is there any way of forcing that automatically?</p>
<p dir="auto">Thank you for your support.</p>
]]></description><link>https://forum.rexygen.com/topic/75/database-value-as-parameter</link><generator>RSS for Node</generator><lastBuildDate>Tue, 10 Nov 2026 21:59:50 GMT</lastBuildDate><atom:link href="https://forum.rexygen.com/topic/75.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 20 Nov 2019 14:02:48 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Database value as parameter on Wed, 20 Nov 2019 20:43:40 GMT]]></title><description><![CDATA[<p dir="auto">Hi George,</p>
<p dir="auto">if I understand correctly you are trying to write (change) parameter inside function block (TIMER_:pt) from the running project, right?</p>
<p dir="auto">Have a look at function block called SETP*: <a href="https://www.rexygen.com/doc/PDF/ENGLISH/BRef_ENG.pdf#page=307">https://www.rexygen.com/doc/PDF/ENGLISH/BRef_ENG.pdf#page=307</a></p>
<p dir="auto">This group of blocks enables you to remotely change parameters (Real, Integer, Bool) of function blocks.</p>
<p dir="auto">If this is not answering your question, please, let me know <img src="https://forum.rexygen.com/assets/plugins/nodebb-plugin-emoji/emoji/android/1f642.png?v=6d51e091ff9" class="not-responsive emoji emoji-android emoji--slightly_smiling_face" style="height:23px;width:auto;vertical-align:middle" title=":)" alt="🙂" /></p>
]]></description><link>https://forum.rexygen.com/post/242</link><guid isPermaLink="true">https://forum.rexygen.com/post/242</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Wed, 20 Nov 2019 20:43:40 GMT</pubDate></item></channel></rss>
