<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Monarco HAT AO reading In Node-red]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">in Node-red driver for Monarco HAT, I didn't see the reading only the value for the AO.</p>
<p dir="auto">Could you modify the driver/AO Node by adding an output--&gt; if no input, just read the AO actual value</p>
<p dir="auto">Thanks a lot<br />
Emmanuel</p>
]]></description><link>https://forum.rexygen.com/topic/80/monarco-hat-ao-reading-in-node-red</link><generator>RSS for Node</generator><lastBuildDate>Mon, 08 Jun 2026 07:44:09 GMT</lastBuildDate><atom:link href="https://forum.rexygen.com/topic/80.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 29 Nov 2019 17:11:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Monarco HAT AO reading In Node-red on Tue, 10 Dec 2019 13:02:08 GMT]]></title><description><![CDATA[<p dir="auto">Hi Emmanuel,<br />
glad you like the Monarco HAT.</p>
<li>Monarco HAT + REXYGEN =&gt; use this forum</li>
<li>Monarco HAT + other programming language =&gt; please use direct e-mail support</li>
<p dir="auto">Thank you.</p>
]]></description><link>https://forum.rexygen.com/post/262</link><guid isPermaLink="true">https://forum.rexygen.com/post/262</guid><dc:creator><![CDATA[jaroslav_sobota]]></dc:creator><pubDate>Tue, 10 Dec 2019 13:02:08 GMT</pubDate></item><item><title><![CDATA[Reply to Monarco HAT AO reading In Node-red on Mon, 09 Dec 2019 08:32:16 GMT]]></title><description><![CDATA[<p dir="auto">Hi Jaroslav,</p>
<p dir="auto">Thanks for your reply.<br />
For monarco Hat, i didn't see forum, i'll go for private mail next time ?<br />
Anyway, great product.<br />
Regards</p>
]]></description><link>https://forum.rexygen.com/post/258</link><guid isPermaLink="true">https://forum.rexygen.com/post/258</guid><dc:creator><![CDATA[bigmanvstrashman]]></dc:creator><pubDate>Mon, 09 Dec 2019 08:32:16 GMT</pubDate></item><item><title><![CDATA[Reply to Monarco HAT AO reading In Node-red on Tue, 03 Dec 2019 09:22:27 GMT]]></title><description><![CDATA[<p dir="auto">Hi Emmanuel,<br />
please note that this forum is intended for <a href="https://www.rexygen.com">REXYGEN</a>-related questions.</p>
<p dir="auto">There is no mechanism to read the AOs of the <a href="https://www.monarco.io">Monarco HAT</a>. These are write-only. The Monarco HAT expects frequent periodic updates of the AOs, so there should be no need to read them.</p>
]]></description><link>https://forum.rexygen.com/post/253</link><guid isPermaLink="true">https://forum.rexygen.com/post/253</guid><dc:creator><![CDATA[jaroslav_sobota]]></dc:creator><pubDate>Tue, 03 Dec 2019 09:22:27 GMT</pubDate></item></channel></rss>
