<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Modbus : converting data from two registers into float]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">Wish you happy new year to team and users !</p>
<p dir="auto">I have some dificulties to convert the modbus data from a device (here a mass flow).</p>
<p dir="auto">I retrieve the data, but i need to convert it.<br />
Here the configuration :</p>
<li>Reading holding register (3)</li>
<li>quantity : 2 (u16)</li>
<p dir="auto">I need a 32-bit float (SGL) after the conversion.<br />
I tried different configuration but without success.<br />
May be need some Swap before join ?</p>
<p dir="auto">Thanks for your help</p>
<p dir="auto">Emmanuel.</p>
]]></description><link>https://forum.rexygen.com/topic/87/modbus-converting-data-from-two-registers-into-float</link><generator>RSS for Node</generator><lastBuildDate>Sun, 18 Oct 2026 03:56:36 GMT</lastBuildDate><atom:link href="https://forum.rexygen.com/topic/87.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 08 Jan 2020 07:47:24 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Modbus : converting data from two registers into float on Fri, 17 Jan 2020 12:15:02 GMT]]></title><description><![CDATA[<p dir="auto">Thanks Thomas<br />
I'll try these parameters.</p>
<p dir="auto">PS : later, cause a collegue take my device...</p>
]]></description><link>https://forum.rexygen.com/post/288</link><guid isPermaLink="true">https://forum.rexygen.com/post/288</guid><dc:creator><![CDATA[bigmanvstrashman]]></dc:creator><pubDate>Fri, 17 Jan 2020 12:15:02 GMT</pubDate></item><item><title><![CDATA[Reply to Modbus : converting data from two registers into float on Thu, 09 Jan 2020 14:35:30 GMT]]></title><description><![CDATA[<p dir="auto">Hi Emmanuel,</p>
<p dir="auto">thanks for your question. Can you share configuration of Modbus in your project (or preferably whole REXYGEN project if possible) so I can have a look at the settings you used?</p>
<p dir="auto">There is possibility to Swap Bytes or <strong>Swap Words</strong> at each Modbus item - did you try that?</p>
<p dir="auto"><img src="/assets/uploads/files/1578580525088-cd3523e2-a8bd-412d-8a22-8a81e6486dde-image.png" alt="0_1578580522900_cd3523e2-a8bd-412d-8a22-8a81e6486dde-image.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.rexygen.com/post/281</link><guid isPermaLink="true">https://forum.rexygen.com/post/281</guid><dc:creator><![CDATA[cechurat]]></dc:creator><pubDate>Thu, 09 Jan 2020 14:35:30 GMT</pubDate></item></channel></rss>
