    Animation object leaving a trail
    707
      stepan.ozana
      Hi, is there a way how to animate an object in HMI web visualization so that it would leave a trail behind during movement? I'd like to animate a simple path in 2d and to see the current movement and the history path in the form of a trace, maybe represented by a point. For example, 2D moving a rectangle whose center point would leave a trail. Or, as shown in the attachment, animating end points of inverted pendulum's links. Thanks, Stepan
        Hello Stepan,
        There is a XYChart component in the CHARTS library in the HMI Designer. It shows several points (lines) stored in the internal buffer. So, the trail is represented by several historical points.
          stepan.ozana @ondrej_severa
          @ondrej_severa Thank you so much for efficient help.
          • ondrej_severaO ondrej_severa locked this topic on
