    Initialization of string in REXLANG
    833
      Scoobsalamander
      I got this warning in the Compiler Window but everything is working fine :
      "Warning compiling file 'WasteSrcfile.c' (line 30): variable 'stringTemp' is used without initialization"
      The initialization was one like this :
      char stringTemp[80];
      Something like this, to initialize an empty string will not work :
      char stringTemp[80] = "";
        reitinge @Scoobsalamander
        @scoobsalamander
        Hi, you can divide the initialization into two commands:
        stringTemp = "";
        if you want to be sure that the array is empty. The warning will disappear.
          Scoobsalamander @reitinge
          @reitinge I did try this before but then I can't even compile due to an error.
          But apparently it was because I did the initialization of this string inside the main routine.
          Bizarre that it is throwing a warning for the string 'stringTemp' and not for the long variable 'index'.
          Both are only used inside the main routine.
          This is the complete code which is now running without a warning :
          //assigning inputs to variables, these variables are READ-ONLY
          double input(0) inputGLAS;
          double input(1) inputGFT;
          double input(2) inputPMD;
          double input(3) inputRA;
          double input(4) inputTEXT;
          double input(5) inputP_K;
          //assigning variables to outputs, these variables are WRITE-ONLY
          string output(0) stringOUT; //value to send to y0 output
          //the init procedure is executed once when the REXLANG function block initializes
          long init(void)
          	return 0;
          //the main procedure is executed repeatedly (once in each sampling period)
          long main(void)
          	long index = 0;
          	//char stringTemp[80];
                  stringTemp="";
          	strcat(stringTemp,"Vergeet+niet+volgend+vuilnis+buiten+te+zetten+:+");
          	if (inputGLAS!=0)
          		strcat(stringTemp,"Glas");
          		index=index+1;
          	if (inputGFT!=0)
          		if (index!=0)
          			strcat(stringTemp,",+");
          		strcat(stringTemp,"GFT");
          		index=index+1;
          	if (inputPMD!=0)
          		if (index!=0)
          		strcat(stringTemp,"PMD");
          		index=index+1;
          	if (inputRA!=0)
          		if (index!=0)
          		strcat(stringTemp,"Restafval");
          		index=index+1;
          	if (inputTEXT!=0)
          		if (index!=0)
          		strcat(stringTemp,"Textiel");
          		index=index+1;
          	if (inputP_K!=0)
          		if (index!=0)
          		strcat(stringTemp,"Papier+en+Karton");
          	stringOUT=stringTemp;
          	return 0;
          //the exit procedure is executed once when the task is correctly terminated
          // (system shutdown, downloading new control algorithm, etc.)
          long exit(void)
          	/* PUT YOUR CODE HERE */
          	return 0;
          • Bradly999B
            Bradly999 Banned
