    Disabling rexlang compile warnings
    2 Posts 2 Posters 822 Views
      sadilekivan
      In one of my codes I'm getting a warning on not using a variable even though I kinda do, what #pragma should I use to disable getting this warning
      Warning compiling file '../.rexlang/database.c' (line 29): variable 'dateInterval' is assigned but not used
      I tried #pragma warning(disable: 4189) but thats no good.
      Thanks in advance!
        I do not have any better advice than to add this line to your code, which will make the compiler believe that the variable dateInterval is used.
        dateInterval = dateInterval;
        Can you share or send your code leading to such a false warning? Thank you.
