    JSON string parsing issue
    2 Posts 2 Posters 819 Views
      Mkrupicka
      Hello all in REXYGEN!
      I have issue with parsing JSON object through PJSOCT block.
      The input to the PJSOCT block is string, the output is also suppost to be a string but it is somehow interpretted as number and moreover represented in exp format. This destroyes long integer variables that I receive from communication partner and need to process in REXYGEN executive.
      In the enclosed example a simple JSON object is parsed with integer id parameter:
         "status":"success",
         "id": 456877932143130020
      but PJSOCT outputs the id parameter as 4.5687793214313e+17
      Could you help, please?
      Thanks and Regards,
      Michal
        cechurat @Mkrupicka
        @mkrupicka Hello Michal,
        thank you for your post. You are right - the behaviour of PJSOCT function block is not as one would expect. However it is also caused by format of "id" item - since the value is written without quotation marks it represents number by the definition.
        I would use different approach:
        • search the string for substring "id"
        • offset the position (I presume that the message structure is given)
        • extract substring (I presume that the ID length is given)
        If you need any help just let me know.
