    PT100 thermocouple ADC conversion UniPi
    General
    5
    949
      Jarek
      Hi. I would like to create automatic firing furnace control on the Rexygen system. In the past, I already did one project on Rexygen, but it was floor heating where I could use sensors on the 1-wire bus. In the case of a firing furnace, this is not possible due to high temperatures, so PT100 type thermocouples are the only solution. Can you please advise me which ADC or RS485 converter to use to communicate with the Rexygen system, which should run best on the UniPi platform? Thanks for the advice.
      cechuratC 1 Reply Last reply Reply Quote 1
        cechurat @Jarek
        @jarek Hi Jarek,
        Thanks for your question. Have a look at this old forum topic: https://www.rexygen.com/oldforum/viewtopic.php@id=182.html (some links won't work however the idea of the solution is clear).
        If I can be of any assistance just drop me a line.
        Cheers, Tomas
        J 2 Replies Last reply Reply Quote 0
          Jarek @cechurat
          @cechurat Ok thanks for the advice.
            Jarek @cechurat
            @cechurat I found one more interesting solution. Do you think it could work with the Rexygen system on the UniPi platform?
            https://store.comwintop.com/products/16-channels-k-type-thermocouple-rs485-modbus-output-temperature-acquisition-module?variant=43703087694051
              cechurat @Jarek
              @jarek If the UniPi you are using have RS485 bus it will work.
