    got some errors during installing REXYGEN for UniPi
    Scheduled Pinned Locked Moved General discussion
    5 Posts 3 Posters 2.6k Views
    • gninausG
      gninaus
      Re: New Raspbian Version Buster was released this month
      Followed the installation for UniPi and got some errors:
      Setting up owserver (3.2p3+dfsg1-2) ...
      Job for owserver.service failed because the service did not take the steps required by its unit configuration.
      See "systemctl status owserver.service" and "journalctl -xe" for details.
      invoke-rc.d: initscript owserver, action "start" failed.
      ā— owserver.service - Backend server for 1-wire control
      Loaded: loaded (/lib/systemd/system/owserver.service; disabled; vendor preset: enabled)
      Active: activating (auto-restart) (Result: protocol) since Wed 2019-07-31 21:48:45 CEST; 231ms ago
      Docs: man:owserver(1)
      Process: 662 ExecStart=/usr/bin/owserver -c /etc/owfs.conf (code=exited, status=0/SUCCESS)
      Main PID: 662 (code=exited, status=0/SUCCESS)
      Jul 31 21:48:45 raspberrypi03 systemd[1]: owserver.service: Service RestartSec=100ms expired, scheduling restart.
      Jul 31 21:48:45 raspberrypi03 systemd[1]: owserver.service: Scheduled restart job, restart counter is at 1.
      Jul 31 21:48:46 raspberrypi03 systemd[1]: Stopped Backend server for 1-wire control.
      dpkg: error processing package owserver (--configure):
      installed owserver package post-installation script subprocess returned error exit status 1
      dpkg: dependency problems prevent configuration of rex-owsdrvt:
      rex-owsdrvt depends on owserver; however:
      Package owserver is not configured yet.
      dpkg: error processing package rex-owsdrvt (--configure):
      dependency problems - leaving unconfigured
      dpkg: dependency problems prevent configuration of rexygen-runtime:
      rexygen-runtime depends on rex-owsdrvt (= 2.50.9-10679~Raspbian~stretch); however:
      Package rex-owsdrvt is not configured yet.
      dpkg: error processing package rexygen-runtime (--configure):
      Errors were encountered while processing:
      owserver
      rex-owsdrvt
      rexygen-runtime
      E: Sub-process /usr/bin/dpkg returned an error code (1)
        thanks for reporting this. The problem is with owserver installation in Buster.
        Can you try running
        sudo dpkg --configure -a
        We'll definitely try to reproduce the problem here on our testbench in the next week. Will get back to you.
          I am not able to reproduce the problem. With the latest installation scripts, everything gets installed correctly.
          Any updates on your side?
          gninausG 1 Reply Last reply Reply Quote 0
          • gninausG
            gninaus @jaroslav_sobota
            @jaroslav_sobota
            After installing Buster Lite Image I made manual install of owserver.
            sudo apt install owserer
            During that install I got the same error messages.
            Reboot and install rex with unipi script.
            Everything was installed without any error.
            Raspi is up and running without any issues.
              MaxJet Banned
