    Rexcore-runtime not Running after installation
    Bug reports, Feature requests
    732
    • gninausG
      gninaus
      I did a fresh Installation for a RaspberryPi 2b with Debian Bookworm. The rexcore 3.0.3 is crashing with a Core Dump when staring the rexcore.service.
      gninaus@raspberrypi03:~ $ systemctl status rexcore.service
      × rexcore.service - REXYGEN Runtime Core (RexCore)
      Loaded: loaded (/lib/systemd/system/rexcore.service; enabled; preset: enabled)
      Active: failed (Result: core-dump) since Thu 2024-11-07 13:04:26 CET; 1h 57min ago
      Duration: 402ms
      Main PID: 4080 (code=dumped, signal=ILL)
      CPU: 147ms
      Nov 07 13:04:26 raspberrypi03 systemd[1]: Started rexcore.service - REXYGEN Runtime Core (RexCore).
      Nov 07 13:04:26 raspberrypi03 systemd[1]: rexcore.service: Main process exited, code=dumped, status=4/ILL
      Nov 07 13:04:26 raspberrypi03 systemd[1]: rexcore.service: Failed with result 'core-dump'.
        Hi Guenther,
        Thank you for your bug report. Our developers fixed that immediately. The fix is now under test, and I will let you know once it is publicly available.
        Thank you for your understanding.
          cechurat @gninaus
          @gninaus Hi Guenther,
          the fix is available in our daily build repository: https://download.rexcontrols.cz/partner/daily/
          Feel free to test it and report back.
