    Problems reading from PCF8574A
    Scheduled Pinned Locked Moved Communication (RS232, RS485, I2C, SPI, UDP, TCP, ...)
    6 Posts 2 Posters 1.3k Views
      AlexanderH
      Hello, I am Alexander and probing a lot with Rexygen, with good results until now. However, at this moment I am trying to read data from a PCF8574A, without succes. I am new with respect to the Rexlang block and i2c.
      Below my code:
      • REXLANG - Using the PCF8574A as Digital Input via I2C
      string parameter(0) i2c_dev; // the I2C bus is defined by the p0 parameter
      //assigning inputs to variables, these variables are READ-ONLY
      long input(3) digital_out; //the signal controlling the outputs is connected to input u3 of the REXLANG block
      long output(10) digital_in; //the state of the input pins is published via output y10 of the REXLANG block
      //declaration of variables
      long i2c_bufTx[3]; //buffer for transmitting data
      long i2c_bufRx[3]; //buffer for receiving data
      long i2c_bus_handle;
      long i2c_chip_address;
      long i2c_write_count;
      long i2c_read_count;
      long i2c_ret_fun;
      //the init procedure is executed once when the REXLANG function block initializes
      long init(void)
      i2c_bus_handle = OpenI2C(i2c_dev); // open I2C bus
      i2c_chip_address = 0x38; // 7-bit address of the I2C device
      i2c_ret_fun = I2C(i2c_bus_handle, i2c_chip_address, i2c_bufTx, i2c_write_count, i2c_bufRx, i2c_read_count);
      return 0;
      //the main procedure is executed once in each sampling period
      long main(void)
      //Reading inputs
      i2c_bufTx[0] = 0x71; //Slave address (0x38) including the reading bit (1)
      i2c_bufTx[1] = digital_out; //masking the data to control the outputs
      i2c_write_count = 2;
      i2c_read_count = 0;
      //Controlling outputs
      i2c_write_count = 0;
      i2c_read_count = 1;
      digital_in = i2c_bufRx[0]; //publishing the received data
      return 0;
      //the exit procedure is executed once when the task is correctly terminated
      // (system shutdown, downloading new control algorithm, etc.)
      long exit(void)
      if(i2c_bus_handle>=0) Close(i2c_bus_handle); // close I2C bus
      return 0;
      Hopefully somebody can help me and tell/show me what I am doing wrong.
      J 1 Reply Last reply Reply Quote 1
        Jan Reitinger @AlexanderH
        @AlexanderH Hi Alexander,
        do you see any error messages in the system log? If so, what kind?
        Does setting the outputs work as expected?
        When reading inputs, I think you should both write and read within the same I2C() call — in other words, both counters should be non-zero. Usually, sending a request and receiving a response over I²C takes much less time than the REXYGEN task execution period. That’s why the I2C() function is designed to send data and, if a response is expected, receive it within the same cycle. I don’t know the exact details of the PCF8574A protocol, but I would assume that you need to perform the write and the read together in one call.
        By the way, the code you pasted looks a bit broken here on the forum – that’s probably due to Markdown formatting. Please enclose the entire script in a code block using triple backticks (```) or upload it here as a text file. That way it will be much easier to read.
        A 3 Replies Last reply Reply Quote 0
          AlexanderH @Jan Reitinger
          @Jan-Reitinger Hi Jan,
          I tried already several things. So much I lost count already.
          I dont get any error in the system log screen. But i think i am not getting it in the read modus.
          Hopefully somebody can help me with this problem.
          With kind regards,
          Alexander
            @Jan-Reitinger , Dear Jan,
            yesterday I was not in the opportunity to include the code. Below the (little modified) code in a better way. Thank you already very much for your reply.
            *   REXLANG - Using the PCF8574A as Digital Input via I2C
            long i2c_ret_fun;
            long init(void)
            return 0;
            long main(void)
            //Reading inputs
            i2c_bufTx[0] = 0xFF; //Slave address (0x38) including the reading bit (1)
            i2c_write_count = 1;
            i2c_read_count = 0;
            i2c_read_count = 1;
            return 0;
            long exit(void)
            return 0;
              @Jan-Reitinger, Hi Jan,
              I solved the problem and can read from the PCF8574.
              Thank you very much for pointing me in the right direction :-).
              So this problem is solved -).
              With kind regards,
              Alexander
                @AlexanderH Hi,
                I'm sorry. For some reason I didn't get an email notifying me that you had replied. I'm glad you finally resolved the issue.
