    Core Error "Configuration requires higher license than available on the target device"
    Scheduled Pinned Locked Moved General discussion
    3 Posts 2 Posters 655 Views
    • gninausG
      gninaus
      I got an Core Error "Configuration requires higher license than available on the target device"
      Rex is running at the latest 3.0.5 Version, at the project were no changes since migrating from 2.50.
      Also the project seams to run well.
        Jan Reitinger @gninaus
        Hi @gninaus,
        With version 3.0, REXYGEN introduced a new licensing policy. You can find the details here:
        https://eshop.rexcontrols.com/pages/licensing-policy
        Could you please send us your license information at support@rexygen.com?
        You can find the license info via REXYGEN Studio by using the menu Target -> Connect and then again Target -> Licensing.
        Also, please attach the REXYGEN Studio Compiler output related to licensing. Here’s an example:
        This will help us identify what part of the configuration requires a higher license and provide further guidance.
          Jan Reitinger @Jan Reitinger
          In this specific case, the error message "Configuration requires higher license than available on the target device" indicates that RexCore did not find the new version of the license. If an older license version is present on the device and is sufficient concerning the scope of the project, this information should appear in the log and the project should run normally. In such a case, please ignore the error message.
          This error message will be revised in future versions of REXYGEN.
