Monarco HAT AO reading In Node-red
in Node-red driver for Monarco HAT, I didn't see the reading only the value for the AO.
Could you modify the driver/AO Node by adding an output--> if no input, just read the AO actual value
Thanks a lot
Emmanuel -
Hi Emmanuel,
please note that this forum is intended for REXYGEN-related questions.There is no mechanism to read the AOs of the Monarco HAT. These are write-only. The Monarco HAT expects frequent periodic updates of the AOs, so there should be no need to read them.
Jaroslav -
Thanks for your reply.
For monarco Hat, i didn't see forum, i'll go for private mail next time ?
Anyway, great product.
Regards -
Hi Emmanuel,
glad you like the Monarco HAT.- Monarco HAT + REXYGEN => use this forum
- Monarco HAT + other programming language => please use direct e-mail support
Thank you.
