    dygraph - color labels and scale of both axes.
    hmi designer dygraph css custom
    768
      How can we change the color of the labels/scale of the x- and y-axis? I have a dark background and the black labels are almost not visible.
      2021-01-11 16_25_50.png image url)
        thanks for asking this question. It is possible to change the color of axes labels by introducing CSS style - see Dygraph doc: https://dygraphs.com/css.html
        In order to make it running with REXYGEN HMI follow these instructions and see also example attached - dygraph-axis-label-css.zip
        • Create "CUSTOM" directory in hmisrc directory
        • Create "css" directory in "CUSTOM" directory
        • Create CSS file in "css" directory with following naming convention: "anyName".css
        • Paste following code (it will change color of x and y labels to yellow):
        .dygraph-axis-label-x{
        	color:yellow;
        .dygraph-axis-label-y{
        	color:yellow;
        • Open your *.hmi.svg file containing the TRND component
        • Open Configuration dialog (Ctrl + E) and manually fill all used libraries in most cases GENERAL and CUSTOM. Be sure to include all of them - e.g. if you use any component from HVAC library, add line containing HVAC.
        If you need any assistance, let me know.
          Thanks for the swift reply, it's working like a charm..... and we learned again something 🙂
          Grtz,
          Kris
            Awesome! Thanks for feedback 😉
