    Archive Export
    archive rexarc
    4
    876
      RSanders
      I have the archive function set to store to disk. Is there a way to retrieve this archive using SSH, Rexygen Diagnostics, or other? If so, what format is the file, the file name, and directory, and how do I interpret it?
        Hi Russel,
        starting REXYGEN version 2.50.10 there is linux command line utility called RexArc available. It allows you to convert archive files to CSV/JSON files with specified parameters such as custom header, filters, etc.
        Install procedure:
        apt update
        apt install rexarc
        Help:
        RexArc --help
            -yNo`          -sm+          .oo.          +Ny-          `oNy:
         .omMMMMm:      .omMMMMd.     `+dMMMMd+`     .hMMMMmo.      :mMMMMmo.
        oMMMMMMMMMy.   oMMMMMMMMN/   :NMMMMMMMMN:   /NMMMMMMMMo   .yMMMMMMMMMo
         :mMMMMMMMMN+`  +NMMMMMMMMy`  /NMMMMMMN/  `yMMMMMMMMN+  `+NMMMMMMMMm:
          `oNMMMMMMMMh.  .hMMMMMMMMm-  .dMMMMm-  -dMMMMMMMMh.  .hMMMMMMMMNo`
            -hMMMMMMMMN+   oNMMMMMMMN/  `hMMh`  /NMMMMMMMNo`  /NMMMMMMMMh-
              +NMMMMMMMMy`  :mMMMMMMMM+  `yy`  +NMMMMMMMm:  `yMMMMMMMMN+
               .hMMMMMMMMm-  .dMMMMMMMMs      oMMMMMMMMd.  -dMMMMMMMMh.
                `oNMMMMMMMN/  `yMMMMMMMMy`   sMMMMMMMMh`  /NMMMMMMMNo`
                  :mMMMMMMMNo  `sMMMMMMMMy`  oMMMMMMMy`  +NMMMMMMMm:
                   .dMMMMMMMMs   oMMMMMMMMy   oMMMMMs   oMMMMMMMMd.
                    `hMMMMMMMMs   oMMMMMMMMy   sMMMs   sMMMMMMMMh`
                     `yMMMMMMMMy   oMMMMMMMMs   hMs   sMMMMMMMMy`
                       sMMMMMMMMs   sMMMMMMMM+  `o   sMMMMMMMMy
                        sMMMMMMMMo   yMMMMMMMM:     oMMMMMMMMy
                         yMMMMMMMM+  `dMMMMMMMN.   /MMMMMMMMy
                   _____  ________   ____     _______ ______ _   _
                  |  __ \|  ____\ \ / /\ \   / / ____|  ____| \ | |
                  | |__) | |__   \ V /  \ \_/ / |  __| |__  |  \| |
                  |  _  /|  __|   > <    \   /| | |_ |  __| | . ` |
                  | | \ \| |____ / . \    | | | |__| | |____| |\  |
                  |_|  \_\______/_/ \_\   |_|  \_____|______|_| \_|
        RexArc is an utility to export data from REXYGEN Archives.
        Usage: RexArc [OPTION]... [ARCHIVE_NAME]
                e.g. Export all data to a JSON file:
                         RexArc my_archive > out.json
                e.g. Export all data to a CSV file with header:
                         RexArc --csv --csv-header "Archive export \n Date; Time; DataType; ; ; Item ID; Data1" my_archive > out.csv
                e.g. Export data in a specified timespan:
                         RexArc -ft1 "2019-01-01 00:00:00,000" -ft2 "2019-01-01 01:00:00,000" my_archive
                e.g. Export data for specified IDs only:
                         RexArc -f 1..3,5 my_archive
        General options:
                -h, --help                      show this manual
                -v, --version                   show program version
                -s, --scan                      scan the input path for available archives
                -fn, --archive                  archive name to export data from,
                                                can be also specified as last parameter
                -ic, --item-count               maximum count of items to export
                -i, --input                     path to 'arc' directory or single '.rea' file,
                                                default value is '/rex/arc'
                -o, --output                    path to output file,
                                                if not specified, output is directed to stdout
                -ve, --verbose                  verbose mode
        Filter options:
                -ft1, --from-timestamp          from time
                -ft2, --until-timestamp         until time
                -f, --filter-id                 filter data by ID, e.g. 1..5,8,10..20
                -nd, --no-data                  filter out data
                -ne, --no-events                filter out events
                -nl, --no-log                   filter out log messages
        JSON only options:
                -p, --pretty-print              pretty-prints the output when exporting to JSON
                -itc, --item-total-count        include a total count of items available,
                                                useful when exporting limited number of items using --item-count
                                                to tell the total count of items that would be exported
                                                if --item-count is not used
        CSV only options:
                -cf, --csv                      exports data to CSV format, default format is JSON
                -ch, --csv-header               specifies custom header for exported CSV,
                                                delimiters for next cell ';' and new line '\n' are supported
                -ccf, --csv-column-filter       specifies the column filter, e.g. 1..5,8,10..20
                -dscl, --delimiter-semicol      use semicolon as column delimiter instead of comma
                -dspc, --delimiter-space        use space as column delimiter instead of comma
                -dtab, --delimiter-tab          use tab as column delimiter instead of comma
        • K
          kotrbus
          Where can I find list of all these extra applications?
            cechurat @kotrbus
            @kotrbus Hi Pavel, there is just RexArc for now. We are aware that it does not have that much publicity - we would like to improve it in next release.
