    Modbus using 485 output and USB
    Monarco HAT
    991
      Is it possible to use both the RS485 on the Monarco HAT and also the the USB on the RPi for Modbus?
      I guess this would need 2 drivers set up for both /dev/ttyAMA0 and /dev/ttyUSB0, would this work?
        thank you for your question. Yes, you are absolutely right. Just be sure that the USB adapter will be always recognised as a /dev/ttyUSB0 device.
        Have a look at udev rules which will help you to achieve this. E.g.:
        https://stackoverflow.com/questions/18736309/linux-input-event-interface-numbering
        http://reactivated.net/writing_udev_rules.html
          there is also one post at old REXYGEN forum which might help you:
          https://www.rexcontrols.cz/forum/viewtopic.php?id=17
