    Solved REXLANG : assigning inputs to an array of doubles
    5
    998
    • A
      Apollo
      Is it possible to assign the input signals to an array of doubles?
      I tried several syntaxes buy I end always up with errors.
      My final goal is to convert them to a string and concatenate before sending by means of UDP.
      something like this....
              string temporary ="";
          	for (a=0; a<12; a++){
      	    	strcat(temporary,double2str(signal[a]);
      	    	if (a<11)
      	    		strcat(temporary,',');
          	Write(long handle, string data)
              dataCnt = Write(hCom,temporary);
        Hi Kris,
        one of the REXLANG limitation is that you can't use input / output arrays (due to internal representation).
        I propose following workaround:
        You can concatenate the doubles outside the REXLANG using String Function Blocks and pass the result String to the REXLANG input.
        A 1 Reply Last reply Reply Quote 0
        • A
          Apollo @cechurat
          @cechurat I was still thinking that the input could not be of the string type.....
          A cechuratC 2 Replies Last reply Reply Quote 0
          • A
            Apollo @Apollo
            Thanks for the info, it is working now.
              cechurat @Apollo
              @apollo said in REXLANG : assigning inputs to an array of doubles:
              Thanks for pointing this out! I will update the docs accordingly.
