    Solved Read and Write Modbus register on HMI
    Modbus RTU
    4
    1.2k
      RexPeter
      Re: Read/Write Modbus
      With reference to the link above, what would be the approach to read the actual value of a register and to use the same "entry box" to write a new value to that same register (if it is possible at all).
      I'm considering something to use a flag checking if "read value" is equal to the "entry field value" in the HMI.
      But maybe I make it to complicated.
      Looking forward for feedback on this.
      Peter
        reitinge @RexPeter
        @rexpeter
        Hi Peter,
        you can use the refresh_from atribute from the Input component, as shown in the picture bellow.
        The value atribute (Input_W in my example) will be assigned to CNI100:icn parameter and the refresh_from (Input_R in my case) atribute to the MBM__readReg:value.
        I think this should work for you.
          RexPeter @reitinge
          @reitinge
          Hi Jan,
          Sorry for a delay in responding to you, but this was the perfect working solution. Thank you very much for that!
          Peter
            reitinge @RexPeter
            @rexpeter
            Hi Peter,
            no problem. I'm glad, it's works.
