    Measuring water flow with UniPi
    4
    4
    707
    • C
      contactform last edited by
      I need advice which REXYGEN system function block to use for water flow measurement. The sensor is connected to my UniPi v1.1 and gives me input 200-400Hz (according to the flow). I need to measure the flow every second. I tried using the COUNT block, but no success. Illustrative image is attached.
      Thank you in advance for your help.
      Karel
      • cechurat
        cechurat last edited by jaroslav_sobota
        Hi Karel,
        the COUNT function block is definitely a good choice, however you should be aware of project timing because of quite high input frequency. I recommend you to have a look at example "0120-23 Frequency of Pulses". Change the project timing so the "tick" parameter is 0.001 s (within the EXEC function block) and "ntick0" according to your needs.
        It means that Quick Task will be executed every 1 ms and task on Level0 every 0.001*ntick0 [s].
        Note that the period of 1ms is quite challenging for Raspberry Pi. I would recommend to use Raspberry Pi 3B+ and watch diagnostics.
        Hope it helps.
        • E
          enovikoff last edited by
          I just had to solve this problem myself. I did some back-of-the-envelope calculations and decided a Pi was just too slow to count pulses this fast AND do all the other work I wanted it to do. So I created a small printed-circuit board with the MCP23017 connected to a SN74LV8154 dual counter after searching fruitlessly for a Pi HAT that included a counter. The counter counts the pulses, the MCP23017 interfaces the parallel outputs of the counter to the I2C bus, and I modified the Rexygen-supplied MCP23017 driver to return the count values and multiply them by calibration constants. Another possibility would be to use a separate microcontroller like the STM32 to count the pulses and return the sum by I2C, but I didn't want to learn the entire software environment of the microcontroller just for that one task.
          This solution is working very well, however it required electrical engineering knowledge and learning a PC board design tool (kicad).
          If you only care about flow rate, another option is to build a RC filter circuit to transform the pulses into a voltage, and use a ADC card to read in the voltage. This doesn't work well for total fluid volume calculations because again, the Pi would be required to integrate the voltages at a high speed.
          jaroslav_sobota 1 Reply Last reply Reply Quote 0
          • jaroslav_sobota
            jaroslav_sobota @enovikoff last edited by
            @enovikoff said in Measuring water flow with UniPi:
            What about the Monarco HAT? It has 2 high-speed counters onboard...
